Duet 2 Wifi won't on.
  • Hi,
    My 3 months old latest ver. duet 2 wifi worked perfectly since last night. Suddenly, the board went off. I switch off and on the power supply. The board is not turning on.
    Then I connect the board and PC with usb cable. The board works again. But as soon as I unplug the usb, the board goes off.
    With power supply connected only. Only the green VIN led is on. I can only detect always on fans have a reading of 24V. Nowhere else has voltage reading.
    I tried to connect the on-board micro usb with a 5v power source (Not a PC). The board works.
    What could be the problem with my board? And any suggestion for how to fix it?
    Thank you.
  • @markxu said in Duet 2 Wifi won't on.:
    If it works from USB it could be the black square chip labeled U3 has failed, take a close look at it, About 2cm in from the fuse between Vin and Bed output.
    and in general https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
