    PT100 Temperature Fault constant in 2000 Celcius (Config Issue)
    • Riev
      Riev last edited by
      I have Heatbed Heater with a Thermistor in Heater 0 (P0 Parameter) and Extruder Heater with 2 wires PT100 Temperature Sensor (with Duet PT100 Daughter Board) in Heater 1 (P1 Parameter).
      Actually I have problem in PT100 Temperature Reading, I use 100 Ohm Test Resistor to check reading in 0 Celcius. But Heater 1 temperature reading always show in 2000 Celcius.
      I checked in Config.g File and make several trial configuration :
      1. Enable both H0 and H1
      I turned off Duet and restart, Actual reading is
      2. Disable H0 and Enable H1
      I turned off Duet and restart, Actual Reading is
      3. Disable H0 and Enable H1, but without write "R4700" in H1
      4. Enable H0 without "R4700" and Enable H1 without "R4700"
      I turned off Duet and restart, Actual Reading is CORRECT
      It seems H1 will be problem if "R4700" is written, but in H0 has no problem if "R4700" is written (when both is enabled).
      Can you explain why "R4700" parameter in H1 setting make H1 reading is incorrect?
      May I run the printer without "R4700" written in configuration file ?
      • Veti
        Veti last edited by
        https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
        you can optionally use the R parameter to specify the value of the reference resistor if it is not 400 ohms.
        4700 is for thermistors. the daughterboard has a different resistor.
        Riev 1 Reply Last reply Reply Quote 0
        • Riev
          Riev @Veti last edited by
          @veti Parameter R4700 for PT100 is automatically generated by RRF Configurator, it is default mode. I just selected sensor channel like picture below.
          • Veti
            Veti last edited by
            yes that is a bug
