    Inverse non-linearity of extruder
    • orcinusundefined
      orcinus
      Has anyone ever experienced Titan extruder extruding with an inverse non-linearity? As in, it extrudes more the faster the requested feedrate, instead of less? This occurs with the unloaded (no hot end attached) extruder - i still have to test with the hotend and see what happens. The load (from the pressure) will likely kick the curve into its inverse.
      Here are my results:
      2mm/s - 50mm requested, 50.575mm pulled in
      5mm/s - 50mm requested, 50.95mm pulled in
      10mm/s - 50mm requested, 51.25mm pulled in
      20mm/s - 50mm requested, 51.45mm pulled in
      50mm/s - 50mm requested, 51.00mm pulled in
      Any ideas on how something like this might be possible from a purely physical/mechanical point of view? 😕
        Check your pinch roller tension?
        • orcinusundefined
          orcinus
          I have.
          In fact, i thought it might be due to pinch roller being too tight.
          Then the hobbed wheel would dig into the filament more (lower radius) at low speeds, and possibly less (greater radius) at high speeds.
          Maybe i didn't test enough of a range, Titans do grip the filament pretty strongly all the way to the point where the idler is very loose.
          • DocTruckerundefined
            DocTrucker
            Are those linear filament speeds you are quoting there? If so that's way out side the normal print range.
            How many samples taken?
            How are you carrying out your test, extrude through the hot end or just drive through the extruder drive?
            I was attempting to do a linear/non linear correction yesterday but I will have to look through the docs as my normal way of validating the correction (extrude while moving the head) no longer seems to work - or I have something odd going on too!
            orcinusundefined 1 Reply Last reply Reply Quote 0
            • orcinusundefined
              orcinus @DocTrucker
              @doctrucker said in Inverse non-linearity of extruder:
              Correct.
              They're outside the normal print range for continuous extrusion, but not for fast retracts and extreme linear advance moves.
              Not many. 2-3.
              Just the extruder.
              I'm currently debugging issues with uneven extrusion, and i did this not so much in order to set up the linear correction as to find what the cause might be. I thought this might reveal any random slippages during retracts or sudden linear advance moves. Much to my surprise, it revealed a weird non-linearity that's irrelevant to the problem, but bizarre enough to warrant investigating further 🙂
              DocTruckerundefined 1 Reply Last reply Reply Quote 0
                DocTrucker @orcinus
                @orcinus Sure, worth figuring out. Interesting point about the effect of pressure advance but the documentation notes currently say that the M592 corrections aren't applied to extruder advance and retract moves.
                I don't know whether or not that is still the case of you are using slicer retract and wipes rather than firmware retracts. It is unlikely to be accurate in those circumstances as it won't be a steady state flow.
                • orcinusundefined
                  orcinus
                  Yes, but i'm not saying they are either.
                  It's that the corrections are often very violent (on long bowdens) by necessity - for example during infills.
                  So speeds like the ones tested are very much in the domain of normal printing - even though you won't get speeds like that on average, or on most of the print, you will in peaks, due to forementioned corrections.
                  So, i'm testing extreme speeds on an uncoupled extruder, doing extruder only moves, where, yes, linear advance is not applied, but it doesn't have to be - as i'm commanding extrusion rates that are (hopefully) similar to what you'd see during violent retractions OR violent linear correction moves.
                  Hope that makes it clearer.
