    Motor settings (Drives) ?
    397
    • Rudy2Aundefined
      Rudy2A
      I am trying to determine and understand how I can accurately calculate the values ​​of my engines for M350. M566. M203. M201. M906.
      Motors X / Y / Z(x2):
      Extruder Motor:
      CoreXY type
      12v
      Can you help me, thanks
      • Vetiundefined
        Veti
        for m350 use x16 microstepping with interpolation.
        motor current should be 70-80% of the max current.
        the rest of the parameter depend on your printer.
        start of with the default parameter from the configurator.
        then print a test print. increase the values and print the same again and compare the result.
        • Rudy2Aundefined
          Rudy2A
          Thank you for the answer,
          However, if I take 70% of the mA of my motor (E) it gives me as value: 1400mA x (70/100) = 980.
          If I put my value found in M906 my extruder makes noise blocking. In addition, if I want to make a G1 E100 I have to put a maximum speed of F1 otherwise my extruder does not extrude the long requested.
          Either my calculation is not good ... or I have to adjust something else too.
          Here my parameters.
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • OBELIKSundefined
            OBELIKS
            The extruder will not be able to extrude at 2000mm/min, but at 600mm/min it should.
            Feedrates of 2000mm/min are used for retractions.
            Also the M906 values are rounded down to 100mA on Duet2 and down to 50mA on Maestro. So use M906 E1000.
            P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
            Original Prusa i3 MK3S
            • Vetiundefined
              Veti @Rudy2A
              @rudy2a said in Motor settings (Drives) ?:
              do the extrusion from the DWC page. There you can select the speed.
              • Rudy2Aundefined
                Rudy2A
                Thank you for that, it's OK: M906 E1000.
                I have a problem on the Z. If I mount M203 Z200 to more than 200, my screws or my Z (double Z) motors make an impossible noise ...
                An expert would be kind enough to analyze my files below and tell me if there is an anomaly on speeds, intensity (mA), or any other ...
                A big thank-you...
                • Vetiundefined
                  Veti
                  a 2mm lead screw wont be able to do 200mm/min with 12v. so reduce the max speed
                  Rudy2Aundefined 1 Reply Last reply Reply Quote 0
                  • Rudy2Aundefined
                    Rudy2A @Veti
                    @veti said in Motor settings (Drives) ?:
                    une vis mère de 2mm ne pourra pas faire 200mm / min avec 12v. alors réduisez la vitesse maximale
                    Thank you for this valuable information, which makes me understand a little more about my configuration ...
                    I would like to understand what value is recommended. A formula exists to calculate the maximum speed of a screw (2 mm) under a 12V supply.
                    Because I guess I can not put a value at random? Between 1 and 199, the Delta is big!
                    I'm sorry, I only start with DUET ...
                    • Vetiundefined
                      Veti
                      do a binary approach.
                      halv it. ie. 100.
                      if it works increase by half i.e 150 then either 175 or 125 etc.
                      if not go 50 then either 75 or 25
                      Rudy2Aundefined 1 Reply Last reply Reply Quote 1
                      • Rudy2Aundefined
                        Rudy2A @Veti
                        @veti
                        Fast, accurate ... thanks for your answers!
