    Mesh probe grid not in defined range on Y axis
    629
    • piperswundefined
      pipersw
      I have a coreXY, with Duet2Wifi rev1.04 and latest stable firmware.
      The probe has 82mm offset with the nozzle in Y.
      In my config file:
      M208 X0 Y-3 Z0 S1 ; Set axis minima
      M208 X300 Y300 Z200 S0 ; Set axis maxima
      M307 H3 A-1 C-1 D-1 ; Disable heater 3 on PWM channel for BLTouch
      M558 P9 H5 F150 T4000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X0 Y82 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X0:300 Y80:220 S20 ; Define mesh grid
      When I run G29, the mesh probing ends at X=300 and Y=118, with no warning. 112 points are probed in the log file.
      I don't understand why the probe don't go to Y=218.
      Y pos Y probe pos
      80 -2
      100 18
      120 38
      140 58
      160 78
      180 98
      200 118 <- end here
      220 138
      240 158
      260 178
      280 198
      300 218 <- theorical end
      fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @pipersw
        Your max Y is shown as 300. Your probe Y offset is shown as 82.
        300 - 82 = 218
        Yet your mesh grid is defined as extending to 220 on the Y axis.
        Change it to 218 and it should work.
        • piperswundefined
          pipersw
          Same behavior with 218, stuck at 118
            dc42 administrators @pipersw
            @pipersw said in Mesh probe grid not in defined range on Y axis:
            Y pos Y probe pos
            80 -2
            100 18
            120 38
            140 58
            160 78
            180 98
            200 118 <- end here
            220 138
            240 158
            260 178
            280 198
            Your probe Y offset is +82 in your G31 command so the probe is 82mm in the +X direction from the nozzle; but your table suggests that the probe is 82mm in the -Y direction from the nozzle. Which is correct?
            piperswundefined 1 Reply Last reply Reply Quote 0
            • piperswundefined
              pipersw @dc42
              @dc42 the probe is Y+82mm
              The second column is the nozzle position reported in the GUI, sorry the mistake
              • fcwiltundefined
                fcwilt
                I don't understand why it is not working with the correct mesh values.
                Just a side note, since the offset is +Y you can set the Y min value in your mesh grid to your actual Y min if you want.
                To speed things up trying to determine what values are messing things up you can change the M557 S20 parameter to P2 and it then should only probe the min/max values in each axis.
                Did you check for another M208 or M557 somewhere that is overriding the values you think are being used?
                • piperswundefined
                  pipersw
                  I have test M557 X0:300 Y80:300 S20 and no warning, stuck at Y=218.
                  The head move to Y=300 with G1 gcode.
                  my config.g:
                  M669 K1 ; switch to CoreXY mode
                  M550 P"COREXY" ; Set machine name
                  M552 S1 ; Enable network
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M569 P0 S0 ; Drive 0 goes forwards (X)
                  M569 P1 S0 ; Drive 1 goes forwards (Y)
                  M569 P2 S0 ; Drive 2 goes forwards (Z)
                  ;M569 P4 S0 ; Drive 4 goes forwards (Z) ; for Bed levelling using multiple independent Z motor drivers
                  ;M569 P5 S0 ; Drive 5 goes forwards (Z) ; for Bed levelling using multiple independent Z motor drivers
                  M569 P3 S1 ; Drive 3 goes backwards (E0)
                  ;M584 X0 Y1 Z2:4 E3 ; three Z motors connected to driver outputs Z
                  ;M671 X-74:-74:330 Y-30:330:150 S1.0 ; Z leadscrews are at (-74,-30), (-74,330) and (330,150), 1mm compensation max
                  M92 X80 Y80 Z400 E820 ; Set steps per mm with 1/16 and BMG extruder with 0.9° stepper
                  M566 X1200 Y1200 Z60 E3000 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X30000 Y30000 Z1000 E6000 ; Set maximum speeds (mm/min)
                  M201 X5000 Y5000 Z500 E10000 ; Set accelerations (mm/s^2)
                  M906 X1400 Y1400 Z1400 E1200 I30 ; Set motor currents (mA) and motor idle factor
                  M84 S30 ; Set idle timeout
                  M574 X1 Y1 S1 ; Set active high and disabled endstops
                  M558 P9 H5 F150 T4000 B1 ; Set Z probe type to bltouch and the dive height + speeds
                  G31 P25 X0 Y82 Z1.030 ; Set Z probe trigger value, offset and trigger height
                  ;M557 X0:300 Y80:218 S20 ; Set Z probe point or define probing grid
                  M307 H0 A254.7 C545.2 D0.9 S1.00 V24.4 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
                  M307 H1 A564.6 C201.7 D6.1 S1.00 V24.1 B0 ; Disable bang-bang mode for the nozzle heater and set PWM limit
                  M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
                  M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                  M143 H1 S275 ; Set temperature limit for heater 1 to 275C
                  M106 P0 S0 I0 F500 H-1 C"HotEnd_Fan" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H1 T45 C"Extruder_Fan" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 H100:101:102 T45:55 L0.3 C"Electronic_Fan" ; set fan 2 value, turn on at 30% if the CPU temperature reaches 45C, and increase to full speed gradually as the temperature rises to 55C
                  M563 P0 D0 H1 ; Define tool 0
                  ; Custom settings
                  M305 P101 S"DuetDriversTemp" ; temperature warning and overheat flags on the TMC2660 on Duet
                  M305 P102 S"DuexDriversTemp" ; temperature warning and overheat flags on the TMC2660 on Duex
                  M912 P0 S6.0 ; calibrate CPU temperature
                  ;M556 S80 X0.125 Y0 Z0.5 ; axis skew compensation
                  M307 H2 A-1 C-1 D-1 ; Disable heater 2 on PWM channel for LED strip
                  M42 P2 S0 ; LED strip on heater 2 off
                  T0 ; Select first tool
                  ;M501 ; Read stored parameters from EEPROM
                  ;M80 ; Turn 24V power supply ON
                  • fcwiltundefined
                    fcwilt
                    This post is deleted!
                    • piperswundefined
                      pipersw
                      M584 is commented because it's for future use of 3 z steppers. Actually I use two z steppers in serial so M584 is not used.
                      If you see my previous post M557 with Y=218 don't work. The y offset probe is 82, so the first value reachable is 80. I have warning for Y lower.
                      In order to reduce test time I use the second line with M557 P2, and I test with the maximum Y to see if I have warning for probe points not reachable and if the probe goes far that 118.
                      I don't know why I have to put the maximum y bed size in M557, in this case the last probe point is Y=218 so good.
                      I don't have a config.override file.
                      I have do some tests with different values for Y in M557, and I have always the probe offset substracted from the defined Y value in M557 for the maximum Y probing.
                      I have 2.03 firmware
                        Can you post your homing files as well?
                        • piperswundefined
                          pipersw
                          Why ? homing files are not concerned by probing, not ?
                          I could post it when I come back to home
                            I want to see if there is something in them like a g92 to set an x y position that could be interfering.
                            • fcwiltundefined
                              fcwilt @pipersw
                              Where is the M584 command that is currently in use?
                              • piperswundefined
                                pipersw
                                I have cleaned my config file, I joined all the configuration files :
                                13_1567539625081_stop.g 12_1567539625081_sleep.g 11_1567539625080_retractprobe.g 10_1567539625080_resume.g 9_1567539625080_pause.g 8_1567539625080_homez.g 7_1567539625080_homey.g 6_1567539625079_homex.g 5_1567539625079_homeall.g 4_1567539625079_heightmap.csv 3_1567539625079_deployprobe.g 2_1567539625079_config.g 1_1567539625078_cancel.g 0_1567539625078_bed.g
                                  I don't think it matters, but you've got a rogue G31 inside your M558 command
                                  M558 P9 H3 F100 T6000 A10 S0.03 R0.5 B0 G31 P25 ; Set Z probe
                                  Remove the G31 P25 and see if it makes a difference. Could explain why the offset isn't seeming to work.
                                  But maybe that error wasn't there previously in which case, I'm at a loss. The other files look ok.
                                  • fcwiltundefined
                                    fcwilt
                                    I downloaded your most recent posted config.g file and I still don't see a M584 command.
                                    Perhaps there are defaults settings being used but I think it best to have an explicit command just to play it safe.
                                    The noise you are hearing may be related to the speed of the move(s).
                                    • piperswundefined
                                      pipersw @fcwilt
                                      @fcwilt said in Mesh probe grid not in defined range on Y axis:
                                      I will add it. thx.
                                      config.g:
                                      M550 P"HYPERCUBE_EVO_NGEN" ; Set machine name
                                      M584 X0 Y1 Z2 E3:4 ; Set drive mapping
