    Having problems with Anycubic Kossel Linear Plus calibration
    calibration
    7.5k
    • SnakeSPundefined
      SnakeSP @Veti
      @Veti That's interesting, but not in nearest future as it is rather complicated.
      • Danalundefined
        Danal
        I have a printer with about 1.1meter bowden. I run 4 to 5 mm retract at 40.
        SnakeSPundefined 1 Reply Last reply Reply Quote 0
        • SnakeSPundefined
          SnakeSP @Danal
          @Danal On what plastic? I use PETG now and it is very prone to stringing. What extruder are you using? I'm on stock Anycubic one, which is not very accurate. Extruder modification is next thing to upgrade in my list after making magnetic arms.
            dc42 administrators @SnakeSP
            @SnakeSP said in Having problems with Anycubic Kossel Linear Plus calibration:
            Measured Z offset at all points from bed.g with G30 S-1 and updated bed.g with H for each point
            If you mean that you just used G30 S-1 to see what Z value it was triggering at, that is NOT what the G30 H parameter is for. It is for correcting for variations in trigger height at different points, if your Z probe doesn't have a consistent trigger height. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Adding_trigger_height_corrections_to_the_bed_g_file.
            • SnakeSPundefined
              SnakeSP @dc42
              @dc42 I'm a bit confused.
              Let's say i'm measuring Z probe height initially at X0 Y0. I go through the steps 1-9 described in https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer section "Measuring the trigger height". I read, let's say, 15.500 at that point. Repeating the steps 7-9 several times show that trigger height is consistent at X0 Y0. I put this value to config.g an do autocalibration.
              After calibration i check the trigger height value at X0 Y0 and get consistent result 15.500.
              But when i move, let's say, to X50 Y0 and do G30 S-1 i get 15.550. I repeat G30 S-1 several times at this point and always get 15.550. So this is consistent.
              I thought that i should add this +0.05 value to G30 in the bed.g file for the corresponding point. Am i wrong?
