    Wrong position after homing axes
    3.8k
    • CoolM8undefined
      CoolM8
      Homing the individual axes separately works without issues. But wenn I execute HomeAll or start a print, the printhead moves in the Y axis about 20mm with the motors giving of a strange noise (unlike the smooth movements wit all other actions) , and den moves to X50 and Y0 and sets this as Home Position X0 Y0.
      What is this additional movement after homing and how can I set Home Position to be at real X0 Y0?
      My printer is Ultimaker Original, and my config.g looks like this:
      M111 S1 ; Debugging off
      G21 ; Work in millimetres
      M564 H0
      M208 X180 Y180 Z205 S0 ; Set axis maxima
      M669 K0
      M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
      M558 P1 ;X1 Y0 Z1 H5 F120 T5000 Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P500 X0 Y0 Z0.35 Set Z probe trigger value, offset and trigger height
      M557 X15:150 Y15:150 S20 ; Define mesh grid
      M350 X32 Y32 Z8 E16 I0 ; Configure microstepping without interpolation
      M92 X157.4804 Y157.4804 Z533.3333 E832 ; Set steps per mm
      M566 X1200 Y1200 Z480 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X8100 Y8100 Z300 E1200 ; Set maximum speeds (mm/min)
      M201 X2500 Y2500 Z100 E250 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1100 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S290; Set maximum heater temperature to 310C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      ;M305 P1 R4700 T100000 B4388
      M305 P1 X200
      M563 P0 D0 H1 ; Define tool 0
      • Vetiundefined
        Veti
        post your home[xyz] and all scripts.
        also
        if you go to x16 with interpolation you will have quieter movement normaly.
        • CoolM8undefined
          CoolM8
          This does not help. As I've already said, it is working correctly while printing, homing etc. The strange movement seems to come from the firmware. When i switch M350 X31 to M350 X16, it behave the same except, the x position is more off after homing that before.
          homeall (all these steps work as excepted):
          ; Relative positioning
          G91
          ; Lift Z
          G1 Z5 F6000
          ; Course home X and Y
          G1 X-210 Y-210 F1800 S1
          ; Move away from the endstops
          G1 X5 Y5 F6000
          ; Fine home X and Y
          G1 X-210 Y-210 F360 S1
          ; Absolute positioning
          G90
          ; Go to first bed probe point and home Z
          G1 X0 Y15 F1800
          G30
          • Vetiundefined
            Veti
            @coolm8 said in Wrong position after homing axes:
            there is a ; in the middle of this command
            your probe does not have an x and y offset?
            you obviously need to change the steps/mm when you change the microstepping.
            try
            M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
            M92 X78.7402 Y78.7402 Z1066.6666 E832 ; Set steps per mm
            try reducing the acceleration and see if the noise disappears.
            set it to something small like 500 for x and y
            • CoolM8undefined
              CoolM8
              @veti said in Wrong position after homing axes:
              X78.7402
              The ; means that i commit out these settings. In the documentation of the duet IR/Probe stands to set it to MP558 P1.
              All other changes do not make any difference. Since this strange sound is coming only from one single movement (the one that comes directly after homing and before moving to the home position). It cannot have anything to do with the configuration. Homing X or Y by it self works all fine and moving the print head after that too. I can print all fine, it only bugs me that the prints are always offset in the x axis.
              • Vetiundefined
                Veti
                duet IR/Probe
                there is no way that you are using this probe and not having an offset.
                • CoolM8undefined
                  CoolM8
                  I did add the offset in X of 40 so now i have:
                  M558 P1
                  G31 P500 X40 Y0 Z0.35
                  But still no difference.
                  • Vetiundefined
                    Veti
                    execute your homeall manually (entering each statement in the console). which one of the commands is producing the noise.
                    • CoolM8undefined
                      CoolM8
                      Ok, did not think about that.
                      It is the following command. G30
                      Strange thing is that if I remove that from homeall.g, it does not probe the bed, but it still has this strange movement in Y and then goes to wrong home position.
                      So homeall.g looks like this now and i can execute every step manualyl without issue:
                      G91
                      ; Lift Z
                      G1 Z5 F6000
                      G1 X5 Y5 F6000
                      ; Fine home X and Y
                      G90
                      G1 X0 Y15 F1800
                      Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      • Vetiundefined
                        Veti
                        G30 determines z=0 by moving the bed up until it triggers the probe.
                        maybe the bed is touching the hotend before the probe triggers. that could make some noise.
                        does the strange movement happen when you execute G1 X0 Y15 F1800 ?
                        • CoolM8undefined
                          CoolM8
                          No, the bed is not touching the sensor. homez.g does also contain the command G30. If i removed from there i get the error 'homing Z failed'.
                          After all axes are hommed i can execute G30 without any issue.
                          So for me it seems like this is the issue:
                          homing X and Y puts the printhead at front left corner of the printer, stopped by endstops at Xmin and Ymin. Then i can move the printhead just fine with manual commands.
                          As soon as G30 gets executed the firmware thinks the print area is about X40 Y0, so the initial movement of G30 from X0 Y0 to X0 Y15 makes this strange motor noise. After it has done the probing an the printhead moves to X40 Y0 and resets the coordinates to X0 Y0. From then on G30 does exactly the same movements as before without any strange noise and smoothly running motors.
                          Somehow I believe the printer thinks moving from real X0 Y0 to X0 Y15 is an impossible move (the motors sound quit like when the run in to force and cannot move any further), but it still executes it.
                          Vetiundefined 1 Reply Last reply Reply Quote 0
                          • Vetiundefined
                            Veti
                            hmm your config seems to be missing the
                            M574 Z1 S2 ; set endstops controlled by probe
                            • Vetiundefined
                              Veti @CoolM8
                              find out where its grinding on. the endstops?
                              • CoolM8undefined
                                CoolM8
                                It is not grinding anywhere. It makes the move correctly just the sound is weird.
                                This is not a mechanical issue, it is only software side.
                                It only happens wile probing, i can make exactly the same move just fine before the Z-axis is homed (i cannot do it afterwards because the software does not allow me to go negativ on the X axis).
                                I alread had the following:
                                M574 X1 Y1 Z1 S0
                                changing to the following did not bring any changes:
                                M574 X1 Y1 S0
                                M574 Z1 S2
                                Why is G30 affecting the X and Y axes anyway?
                                Might it be that i have the Duet Wifi 1 but running recently updated Version:
                                Firmware Electronics: Duet WiFi 1.0 or 1.01
                                Firmware Version: 2.03 (2019-06-13b2)
                                WiFi Server Version: 1.23
                                Web Interface Version: 1.22.6
                                • Vetiundefined
                                  Veti
                                  M558
                                  its not but it might be picking up your X1 in M558 command
                                  try replacing the entire line with
                                  M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                  • CoolM8undefined
                                    CoolM8
                                    This still has no effect on this behavior.
                                    To be exact, the X offset after homing is 58mm. When execute an emergency stop after homing Z, I can move the X-axis to -58 until the endstop triggers. I then can manually go forward 204mm until I reach the end of the other side of the X axis (from -58 to 164). This shows that the motors and the stepping is set up correctly.
                                    I have taken a video of the steps from Z-Axis homing. The strange movement beginns at 1:00 minute into the video. See: https://youtu.be/9m7Y-PwS-pI
                                    • Vetiundefined
                                      Veti
                                      the video is private
                                      • Vetiundefined
                                        Veti
                                        M564 H0
                                        can you remove this? this should not be in a normal config.
                                        also the normal place for the M208 command is after the M84. This should not be a problem for your config i think, but on certain commands the order is important.
                                        • CoolM8undefined
                                          CoolM8
                                          If I remove M554 H0 I cannot home any axis anymore. No matter what i choose homeall, home X, ... I get this error: G0/G1: insufficient axes homed
                                          I fixed the video and it should now be accessible:
                                            Phaedrux Moderator @CoolM8
                                            This is because of this
                                            ; Lift Z
                                            G1 Z5 F6000
                                            You need to add S2 to that G1 Z move so that it can move without being homed first.
