    Wrong position after homing axes
    3.8k
    • CoolM8undefined
      CoolM8
      This does not help. As I've already said, it is working correctly while printing, homing etc. The strange movement seems to come from the firmware. When i switch M350 X31 to M350 X16, it behave the same except, the x position is more off after homing that before.
      homeall (all these steps work as excepted):
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z5 F6000
      ; Course home X and Y
      G1 X-210 Y-210 F1800 S1
      ; Move away from the endstops
      G1 X5 Y5 F6000
      ; Fine home X and Y
      G1 X-210 Y-210 F360 S1
      ; Absolute positioning
      G90
      ; Go to first bed probe point and home Z
      G1 X0 Y15 F1800
      G30
      • Vetiundefined
        Veti
        @coolm8 said in Wrong position after homing axes:
        M558 P1 ;X1 Y0 Z1 H5 F120 T5000 Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
        there is a ; in the middle of this command
        G31 P500 X0 Y0 Z0.35 Set Z probe trigger value, offset and trigger height
        your probe does not have an x and y offset?
        you obviously need to change the steps/mm when you change the microstepping.
        try
        M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
        M92 X78.7402 Y78.7402 Z1066.6666 E832 ; Set steps per mm
        M201 X2500 Y2500 Z100 E250 ; Set accelerations (mm/s^2)
        try reducing the acceleration and see if the noise disappears.
        set it to something small like 500 for x and y
        • CoolM8undefined
          CoolM8
          @veti said in Wrong position after homing axes:
          X78.7402
          The ; means that i commit out these settings. In the documentation of the duet IR/Probe stands to set it to MP558 P1.
          All other changes do not make any difference. Since this strange sound is coming only from one single movement (the one that comes directly after homing and before moving to the home position). It cannot have anything to do with the configuration. Homing X or Y by it self works all fine and moving the print head after that too. I can print all fine, it only bugs me that the prints are always offset in the x axis.
          • Vetiundefined
            Veti
            duet IR/Probe
            there is no way that you are using this probe and not having an offset.
            • CoolM8undefined
              CoolM8
              I did add the offset in X of 40 so now i have:
              M558 P1
              G31 P500 X40 Y0 Z0.35
              But still no difference.
              • Vetiundefined
                Veti
                execute your homeall manually (entering each statement in the console). which one of the commands is producing the noise.
                • CoolM8undefined
                  CoolM8
                  Ok, did not think about that.
                  It is the following command. G30
                  Strange thing is that if I remove that from homeall.g, it does not probe the bed, but it still has this strange movement in Y and then goes to wrong home position.
                  So homeall.g looks like this now and i can execute every step manualyl without issue:
                  G91
                  ; Lift Z
                  G1 Z5 F6000
                  G1 X5 Y5 F6000
                  ; Fine home X and Y
                  G90
                  G1 X0 Y15 F1800
                  Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • Vetiundefined
                    Veti
                    G30 determines z=0 by moving the bed up until it triggers the probe.
                    maybe the bed is touching the hotend before the probe triggers. that could make some noise.
                    does the strange movement happen when you execute G1 X0 Y15 F1800 ?
                    • CoolM8undefined
                      CoolM8
                      No, the bed is not touching the sensor. homez.g does also contain the command G30. If i removed from there i get the error 'homing Z failed'.
                      After all axes are hommed i can execute G30 without any issue.
                      So for me it seems like this is the issue:
                      homing X and Y puts the printhead at front left corner of the printer, stopped by endstops at Xmin and Ymin. Then i can move the printhead just fine with manual commands.
                      As soon as G30 gets executed the firmware thinks the print area is about X40 Y0, so the initial movement of G30 from X0 Y0 to X0 Y15 makes this strange motor noise. After it has done the probing an the printhead moves to X40 Y0 and resets the coordinates to X0 Y0. From then on G30 does exactly the same movements as before without any strange noise and smoothly running motors.
                      Somehow I believe the printer thinks moving from real X0 Y0 to X0 Y15 is an impossible move (the motors sound quit like when the run in to force and cannot move any further), but it still executes it.
                      • Vetiundefined
                        Veti
                        hmm your config seems to be missing the
                        • Vetiundefined
                          Veti @CoolM8
                          find out where its grinding on. the endstops?
                          • CoolM8undefined
                            CoolM8
                            It is not grinding anywhere. It makes the move correctly just the sound is weird.
                            This is not a mechanical issue, it is only software side.
                            It only happens wile probing, i can make exactly the same move just fine before the Z-axis is homed (i cannot do it afterwards because the software does not allow me to go negativ on the X axis).
                            I alread had the following:
                            M574 X1 Y1 Z1 S0
                            changing to the following did not bring any changes:
                            M574 X1 Y1 S0
                            M574 Z1 S2
                            Why is G30 affecting the X and Y axes anyway?
                            Might it be that i have the Duet Wifi 1 but running recently updated Version:
                            Firmware Electronics: Duet WiFi 1.0 or 1.01
                            Firmware Version: 2.03 (2019-06-13b2)
                            WiFi Server Version: 1.23
                            Web Interface Version: 1.22.6
                            • Vetiundefined
                              Veti
                              M558
                              its not but it might be picking up your X1 in M558 command
                              try replacing the entire line with
                              M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                              • CoolM8undefined
                                CoolM8
                                This still has no effect on this behavior.
                                To be exact, the X offset after homing is 58mm. When execute an emergency stop after homing Z, I can move the X-axis to -58 until the endstop triggers. I then can manually go forward 204mm until I reach the end of the other side of the X axis (from -58 to 164). This shows that the motors and the stepping is set up correctly.
                                I have taken a video of the steps from Z-Axis homing. The strange movement beginns at 1:00 minute into the video. See: https://youtu.be/9m7Y-PwS-pI
                                • Vetiundefined
                                  Veti
                                  the video is private
                                  • Vetiundefined
                                    Veti
                                    M564 H0
                                    can you remove this? this should not be in a normal config.
                                    also the normal place for the M208 command is after the M84. This should not be a problem for your config i think, but on certain commands the order is important.
                                    • CoolM8undefined
                                      CoolM8
                                      If I remove M554 H0 I cannot home any axis anymore. No matter what i choose homeall, home X, ... I get this error: G0/G1: insufficient axes homed
                                      I fixed the video and it should now be accessible:
                                        Phaedrux Moderator @CoolM8
                                        This is because of this
                                        ; Lift Z
                                        G1 Z5 F6000
                                        You need to add S2 to that G1 Z move so that it can move without being homed first.
                                        • CoolM8undefined
                                          CoolM8
                                          This is not what I'm looking for. I do not need to disable manual movement before homing and i do not need to overwrite that with manual commnands to move. All i want is G30 to work properly and not do to that strange additional movement that you can see in the video.
                                            Can you send G31 P1 in the gcode console? I suspect that the offset may not be applied correctly.
                                            Have you verified that the steps per mm is correct so that 10mm of requested movement equals 10mm of actual movement?
                                            You can do as you wish, I'm merely explaining what's happening. Please keep in mind that we are only trying to volunteer our time to help you solve your problem. If you would prefer, I can stop trying to assist.
