    Motor idle noise ?
    31
    6472
    • HenrikM
      HenrikM last edited by
      i have this motor idle noise when my motors are on. i dident have that when i have the mks board with TMC2100.
      is it normal or what can it be?
      This on X and Y.
      0.9 deg and 2A. Running in 1600mah
      17HM19-2004S
      On Z.
      1.8deg 1.3A Running in 900mah
      Busheng 17HD40005-22B
      https://youtu.be/cyaQE_TGiWY
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sat Mar 04 2017 15:46:00 GMT+0100 (W. Europe Standard Time)
      M111 S0 		; Debugging off
      G21 			; Work in millimetres
      G90 			; Send absolute coordinates...
      M83 			; ...but relative extruder moves
      M555 P2 		; Set firmware compatibility to look like Marlin
      M208 X0 Y0 Z0 S1 	; Set axis minima
      M208 X340 Y250 Z280 S0  ; Set axis maxima
      M574 X1 Y1 Z1 S0 			; Define active low and unused microswitches
      M558 P5 X0 Y0 Z1 H5 F200 T6000 		; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
      G31 X-40 Y7 Z0.9 P50 			; Set Z probe trigger value, offset and trigger height
      					;Z-offset. Higher value LOWER nozzle height
      					;	   Lower value RAISE nozzle height
      M557 X10:340 Y10:240 S68 		; Define mesh grid
      M307 H3 A-1 C-1 D-1			; disable heater 3, which makes it available for use to control the BLTouch
      M569 P0 S1 	; Drive 0 goes forwards  - X
      M569 P1 S0 	; Drive 1 goes backwards - Y
      M569 P2 S0 	; Drive 2 goes backwards - Z
      M569 P3 S1 	; Drive 3 goes forwards - Extruder
      M350 X16 Y16 Z16 E16  I1		; Configure microstepping with interpolation	16
      M92 X160 Y160 Z1600 E800 		; Set steps per mm				16
      M566 X600 Y420 Z12 E120 		; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z500 E400 		; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E250 		; Set accelerations (mm/s^2)
      M204 P500 T1000				; Set Max acceleration for P=printing moves and T=travel moves
      M906 X1600 Y1600 Z900 E1000 I30 	; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 				; Set idle timeout
      M143 S285 					; Set maximum heater temperature to 285C
      ;M305 P1 X101
      M305 P1 T107000 B10832 C4.891620e-7  R4700 			; Set thermistor + ADC parameters for heater 0 - BED
      M305 P0 T99600 B4388 C0 R4700 					; Set thermistor + ADC parameters for heater 1 - HOTEND
      M307 H0 P96.0, I3.285, D603.9			;Bed
      ;M307 H1 P1.1, I0.011, D51.5 			;Hotend pid
      M307 H1 P17.8, I0.055, D74.9			;Hotend ny pid
      M563 P0 D0 H1 ; Define tool 0
      M550 Black Widow ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      • Ntesla66
        Ntesla66 last edited by
        I've heard a noise not unlike this as well. When I was jogging the the x/y carriage and z axis around for bed leveling, ever so often I would hear it whining at me. I could jog the y or x or z and it might go away. When printing I really couldn't hear it. Following this post because I'm curious. FFCP/DuetWiFi.
        M208 X-128.2 Y-82 Z0 S1 ; Set axis minima
        M208 X293 Y173 Z150 ; Set axis maxima
        M569 P2 S1 ; Drive 2 goes backwards
        M569 P4 S0 ; Drive 4 goes forwards
        M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
        M92 X92.58 Y93.42 Z395 E95:95 ; Set steps per mm
        M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
        M203 X6000 Y6000 Z1800 E1200:1200 ; Set maximum speeds (mm/min)
        M201 X500 Y300 Z250 E250:250 ; Set accelerations (mm/s^2)
        M906 X750 Y750 Z250 E850:850 I30 ; Set motor currents (mA) and motor idle factor in per cent
        • jmjcoke2
          jmjcoke2 last edited by
          Try changing the idle %. M906 X1600 Y1600 Z900 E1000 >I30< to a higher or lower setting.
          • Loffy770
            Loffy770 last edited by
            I have the exact same issue with high frequency sound from the motors.. Gets really tired from listening to it. My old board with TMC2100 was totally silent.
            I think DC42 wrote in another tread that he wanted to know if more people had this issue and that the TMC2660 had tons of possible tweak options…
              I'll try a few different settings on my Kossel and provide some suggestions later.
              • HenrikM
                I have playing around with diffrent idle currents and microsteppings and it dont change a thing. Same sound.
                BUT my Z motor is quite. No sound on that.
                I "heard" that when i playing around and start them one at a time. If i only start Z there is No sound.
                So all my 0.9 deg motors are making that sound. X, Y and extruder. Have titan with ther 0.9deg motor
                i run everything on 24v.
                  What is the inductance of the noisy motors, and what current do you run them at?
                  • HenrikM
                    @dc42:
                    http://omc-stepperonline.kancart.com/item_detail/122-0-9deg-Nema-17-Bipolar-Stepper-Motor-2A-46Ncm-17HM19-2004S#!detail
                    2A runing at 1600mah
                    3.0 mH+-20% (1KHz)
                    My titan i cant Look up now. It is there "official motor" 0.9.
                      Try sending this command:
                      M350 I999 X33203 Y33203 Z33203
                      (that's a letter I before the 999). This is a bit of a guess because I don't have any motors with specifications close to yours to test with.
                      Caution: don't play around with the XYZ values without understanding the TMC2660 data sheet. To go back to default values, use M350 I999 X65972 Y65972 Z65972.
                      There is a slight bug in that sending this command will enable the XYZ motors if they are not already enabled, also disabling/enabling the motors will change the values a little. This will be fixed in the 1.18 release.
                      • Ntesla66
                        @dc42:
                        9.3mH, 750mA, and 5.75 Ohms/phase, 1.8 degree/step on the X and Y motors. Just standard FlashForge steppers.
                        • HenrikM
                          @dc42:
                          When i send M350 I999 X33203 Y33203
                          that come up.
                          21:16:34 M350 I999 X33203 Y33203
                          Drive X does not support 33203x microstepping with interpolation
                          Drive Y does not support 33203x microstepping with interpolation
                          do i send it or change my config?
                          what does it do and does it only apply on my motors or other with same problem can try it?
                          how did you come up with that numbers?
                            Send M906 I100 to set the idle current to 100% so that you can hear the noise better. Move the motors a little to turn them on. Then send the command I suggested and listen for any change in the idle motor noise. Ignore the error messages.
                            • HenrikM
                              @dc42:
                              hmm okay. X is maby little little less noise. hard to compaire. But Y have same sound. so not much diffrence there.
                              There is more noise on Y axis. it has always been so. But it is same motor on Z. and they dident sounded like this with my mks board and TMC2100.
                              They work nice and go very nice when they print. So just the idle noise.
                              i use version 18rc1
                              • nyt
                                nyt last edited by
                                @dc42:
                                I did this and the pitch increases but it's just as loud.
                                This is what it sounds like by default, 1.18.1
                                https://www.youtube.com/watch?v=Ll9lu8ms86s
                                • kuhnikuehnast
                                  kuhnikuehnast last edited by
                                  I've got a similar problem... Used this stepper motors: 17HS19-2004S1
                                  https://www.omc-stepperonline.com/de/hybridschrittmotor/nema-17-bipolar-59ncm-84ozin-2a-42x48mm-4-drähte-w-1m-kabel-and-verbinder-17hs19-2004s1.html
                                  1.8 deg 2A. Actual running at 800ma. Already tried 300 to 1700 with no effort....
                                  Running the DuetWifi on 24V
                                  If I switch on the printer there is no sound, but as soon as I home the axis, there is an awful beeping / wheening on all motors in idle. Also if they are moving, they are quiet loud. On my Anet A8 with TMC2208 (under 12 V) there is nothing to hear?
                                  Are there any solutions on this problem?
                                    This is still on my list to look at. AFAIK Trinamic doesn't give any guidance for setting the chopper control register values, so I need to experiment.
                                    • kuhnikuehnast
                                      Today got my new pancake Extruder Stepper motor. Same issue, but less noisy. ( https://www.omc-stepperonline.com/de/hybridschrittmotor/nema-17-bipolar-18deg-13ncm-184ozin-1a-35v-42x42x20mm-4-drähte-17hs08-1004s.html?search=17HS08-1004S )
                                      Is there any schedule from which the problem is addressed? Unfortunately, I do not know what else I can do about it ..
                                      • nraynaud
                                        nraynaud last edited by
                                        oops, I just changed my power supply from 12 to 24V, and now I have noisy idle motors too. What's funny is that the volume changes with the position, I suspect it's the microstep position I'm hearing.
                                        I have an anycubic i3, here is a picture of the motors: 0_1529094485902_IMG_2032.jpg
                                        here is my configuration:
                                        ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
                                        ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST)
                                        M208 X0 Y0 Z0 U0 S1 ; Set axis minima
                                        M208 X210 Y210 Z200 U200 S0 ; Set axis maxima
                                        ;DUAL Z
                                        M584 X0 Y1 Z2:3 U3 E4 P3
                                        M574 X1 Y1 Z1 U1 S0 ; Set active low endstops
                                        M558 P0 X0 Y0 Z0 H2 F60 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                                        G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                                        M557 X15:195 Y15:195 S20 ; Define mesh grid
                                        M569 P4 S1 ; Drive 4 goes forwards
                                        ; M350 X32 Y32 Z32 E16:16 I1 ; Configure microstepping with interpolation
                                        ; M92 X160 Y160 Z800 E92.6:92.6 ; Set steps per mm
                                        M350 X64 Y64 Z64 U64 E16:16 I1 ; Configure microstepping with interpolation
                                        M92 X320 Y320 Z1600 U1600 E92.6:92.6 ; Set steps per mm
                                        M906 X1100 Y1100 Z800 U800 E1000:1000 I50 ; Set motor currents (mA) and motor idle factor in per cent
                                        M84 S2 ; Set idle timeout
                                        M566 X600 Y600 Z12 U12 E300:300 ; Set maximum instantaneous speed changes (mm/min)
                                        M203 X30000 Y30000 Z1200 U1200 E1800:1800 ; Set maximum speeds (mm/min)
                                        M201 X2500 Y2500 Z500 U500 E3000:3000 ; Set accelerations (mm/s^2)
                                        ; snip -----8<---- 8<---
                                        The irony that I wanted to go to 24V to reduce the noise is not lost to me...
                                        • nraynaud
                                          Can I fiddle with the M350 command live in the web interface when the motors are running (at idle)?
                                          I am trying to change the M350 S parameter and I don't hear a difference.
                                          • fma
                                            fma last edited by
                                            @dc42, what registers are set when using I999? And what params affect the motor noise?
                                            Frédéric
                                              @nraynaud said in Motor idle noise ?:
                                              I would not expect the M350 settings to make a different when the motors are not moving.
                                              nraynaud 1 Reply Last reply Reply Quote 0
                                                dc42 administrators @fma last edited by
                                                @fma said in Motor idle noise ?:
                                                See this thread https://forum.duet3d.com/topic/5392/does-m906-set-rms-or-peak-current. The TOFF parameter appears to be the most important one.
                                                • fma
                                                  fma last edited by
                                                  Thanks! I will ask further questions on this thread...
                                                  Frédéric
                                                  • nraynaud
                                                    nraynaud @dc42 last edited by
                                                    @dc42 yes, I realize it's not smart. decay is all about the end of the step.
                                                    is there a parameter that randomizes the microstep PWM frequency? I don't know what it would be called, dithering or spread spectrum or something of the like.
                                                      dc42 administrators @nraynaud last edited by
                                                      Yes there is a random off-time bit, but it doesn't seem to help much if at all.
