    Mesh leveling
    • ScotY
      ScotY last edited by
      I'm trying to figure out mesh leveling and "think" I've got it setup correctly, but it doesn't really appear to be working. I have a Duet Wifi with recent firmware update and also using an IR sensor. All previously working with the old 5 point leveling setup. The instructions on the Wiki were a bit confusing to me so this is what I've done…
      I created a macro with this:
      M557 X20:120 Y10:220 S40
      G29
      Because it takes a while to do, after having run the macro once, I have sent G29 S1 which, I believe, will used the last height map which is saved? in memory. I've sent G29 S1 and am running a print. It's a large flat part and I see no discernible movement in the z-axis as it prints. What am I doing wrong?
      Thanks!
        It's hard to see Z movement unless you have a gear wheel on the Z drive that you can see rotating, because the amount of movement is small. The M122 diagnostic report includes the type of bed compensation in use.
        • ScotY
          Thanks, David. Here's what M122 results in AFTER running the grid macro:
          M122
          Used output buffers: 1 of 32 (11 max)
          Memory usage:
          Program static ram used: 20276
          Dynamic ram used: 73876
          Recycled dynamic ram: 56
          Current stack ram used: 3304
          Maximum stack ram used: 4288
          Never used ram: 32576
          Last reset 00:02:21 ago, cause: power up
          Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
          Stack: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffff
          Spinning module during software reset: GCodes, available RAM 28868 bytes (slot 3)
          Error status: 0
          Max PWM loop count 0
          Free file entries: 10
          SD card longest block write time: 3.2ms
          MCU temperature: min 35.7, current 39.8, max 42.7
          Supply voltage: min 12.1, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0
          Driver 0: stalled standstill
          Driver 1: stalled standstill
          Driver 2: standstill
          Driver 3: standstill
          Driver 4: standstill
          Current date and time: 2017-04-01 07:18:28
          Slowest main loop (seconds): 0.120956; fastest: 0.000153
          MaxReps: 2, StepErrors: 0, MaxWait: 1556ms, Underruns: 0, 0
          Bed compensation in use: mesh
          Bed probe heights: 0.027 0.067 0.085 0.017 0.015 0.035 -0.028 -0.013 0.005 -0.038 -0.015 -0.025 -0.033 -0.060 -0.040 -0.130 -0.040 -0.030 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
          Probe change coordinates:
          Bed heater = 0, chamber heater = -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is ready with "M122"
          telnet is idle
          file is idle
          serial is idle
          aux is idle
          daemon is idle
          === Network ===
          WiFiServer is running
          SPI underruns 0, overruns 0
          === Webserver ===
          HTTP sessions: 1 of 8
          I tried M122 when I first powered the Duet Wifi on and it reported no bed compensation was in use. If I want to use grid leveling but don't want to wait for the whole process to complete, I would just send G29 S1, correct? The height map is saved on the SD card?
            That's correct.
