    Dual power supply setup with only one ?
    • wylleyundefined
      wylley
      I'm still having trouble with the connector of the extension cable for my atx psu heating so I thought I could use the two different 12v rails and wire them like they were different power supplies for the bed and board. Turns out after mesuring with a multimeter that all the connections of the power supply are connected to a single rail and that the "two 12v rails" is only labeling/advertisement. Can I still wire it like it was 2 power supplies to split the current between the wires even tough its just a regular single rail power supply or not ?
      Thanks for helping
        Yes you can.
