    Updated to firmware 2.03 WiFi not working
    Firmware installation
    • drthomasw3undefined
      drthomasw3
      WiFi light does not turn on. Can turn on with Yat .
      WiFi Ver 1'22
      Web interface 1.22.6
      • fcwiltundefined
        fcwilt
        We need to see your config.g file - and any others that you think might be relevant.
          Can you post your config.g?
          Did you happen to use the web configurator recently to generate a config set?
            drthomasw3
            ; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 15:25:16 GMT-0400 (Eastern Daylight Time)
            M550 P"Tronxy X5SA" ; set printer name
            M667 S1 ; select CoreXY mode
            M911 S10 R11 P'M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000' ; set voltage thresholds and actions to run on power loss
            M569 P3 S0 ; physical drive 3 goes backwards
            M350Z16 I0 ; configure microstepping without interpolation
            M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z400.00 E90.00 ; set steps per mm
            M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
            M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
            M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X330 Y330 Z400 S0 ; set axis maxima
            M574 X1 Y1 Z1 S1 ; set active high endstops
            M574 Z1 S3 ; set endstops controlled by motor stall detection
            M574 Z1 S2 ; set endstops controlled by probe
            M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
            M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
            G31 P500 X-30 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X50:315 Y50:315 S20 ; define mesh grid
            M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
            M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
            M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M552 S1 ; enable network
            M587 S"Bones" P"Gre8Scott;" I10.9.65.119 J10.9.65.248 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            Phaedruxundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @drthomasw3
              @drthomasw3 said in Updated to firmware 2.03 WiFi not working:
              As I suspected. You've been bitten by a recently introduced bug.
              To correct it, all you need do is change the single quotes ' in that M911 command to be double quotes ".
                I also just noticed that you seem to be missing a space after the M350
                  drthomasw3
                  Thank you!!!!!!!!!
