    m671 dual lead screw bed.g
    • mikeboyle24undefined
      mikeboyle24
      i just finish upgrading my cr10mini with a duet wifi
      and ran a g32 it did everything fine intell it got to the end of my bed.g file where i entered in the x y coordinates for example and it ends up hitting X max? if i type it in manual it stops exactly were i want it 🤔 ```
      code_text
      ; generated by RepRapFirmware Configuration Tool v2.0.0 on Thu Aug 29 2019 22:47:39 GMT-0700 (Pacific Daylight Time)
      G29  ; probe the bed and enable compensation
      G30 P0 X60 Y115 Z-99999 ; left lead screw
      G30 P1 X280 Y115 Z-99999 S2 ; right lead screw
        mikeboyle24
        here is my config with the m671 at the end, just not sure if im setting the bed.g coordinates wrong . RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03```
        code_text
        G90                                     ; send absolute coordinates...
        M83                                     ; ...but relative extruder moves
        M550 P"CR10MINI"                        ; set printer name
        M552 S1                                 ; enable network
        M586 P0 S1                              ; enable HTTP
        M586 P1 S0                              ; disable FTP
        M586 P2 S0                              ; disable Telnet
        M569 P0 S1                              ; physical drive 0 goes forwards
        M569 P1 S0                              ; physical drive 1 goes forwards
        M569 P2 S1                              ; physical drive 2 goes forwards
        M569 P3 S1                              ; physical drive 3 goes forwards
        M569 P4 S0                              ; dual z drive
        M584 X0 Y1 Z2:4 E3                        ; set drive mapping
        M350 X16 Y16 Z16 E16 U16 I1                 ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z1600.00 E402.00 U1600.00      ; set steps per mm
        M566 X900.00 Y900.00 Z12.00 E120.00 U12.00     ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00 U180.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E250.00 U20.00     ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E800 U800 I30            ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                 ; Set idle timeout
        M208 X0 Y0 Z0 S1                        ; set axis minima
        M208 X300 Y230 Z285 S0                  ; set axis maxima
        M574 X1 Y1 S1                           ; set active high endstops
        M574 Z1 S2                              ; set endstops controlled by probe
        M558 P5 H5 I1 F120 T6000                   ; set Z probe type to switch and the dive height + speeds
        G31 P500 X-45.4 Y-13 Z0.72                 ; set Z probe trigger value, offset and trigger height
        M557 X15:215 Y15:195 S20                ; define mesh grid
        M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
        M143 H0 S120                            ; set temperature limit for heater 0 to 120C
        M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
        M143 H1 S280                            ; set temperature limit for heater 1 to 280C
        M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0 H1 F0                        ; define tool 0
        G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
        G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
        ; bed leveling lead screw coordinates
        M671 X-30.0:334.0 Y115:115 S0.5         ; lead screw positions
        M501                                    ; load saved parameters from non-volatile memory
          1. You are asking it to probe at X=280 in the second G30 command, however the probe is offset form the nozzle by -45mm in the X direction. So that requires putting the nozzle at X325, which I presume is outside the limit of your machine. So reduce that G30 X coordinate.
          2. You should run the G30 leadscrew levelling commands before mesh probing the bed. Otherwise, the mesh will take account of any tilt that the G30 commands remove. So move the G29 command to the end.
          I didn't spot anything wrong with your config.g file.
          mikeboyle24undefined 1 Reply Last reply Reply Quote 0
            mikeboyle24 @dc42
            @dc42 ok I will make it smaller I wasn’t sure if was asking for the nozzle position at 280 , so when in g30’s commands the offset of the probe is now let’s say zero
