    Cannot initialise SD card
    • wilko
      wilko last edited by
      my Duet Wifi, after working flawlessly for months, has developed a problem reading the SD card. This is what it says:
      Cannot initialise SD card 0: Card is unusable, try another oneRepRapFirmware for Duet WiFi Version 1.15b dated 2016-08-25
      Executing default.g (no configuration file found)...Error, not found
      Network disabled.
      RepRapFirmware for Duet WiFi is up and running.
      Printer is now online.
      So far I tried:
      • re-format supplied SD card. (format in MS-DOS FAT32, then copy the folders 'sys', 'macros', and 'gcode' back onto the card) -> no luck
      • tried a different card I had lying around. -> no luck
      I'm not sure, what I should try next.
      • Does the sd card has to be formatted with a more obscure file system?
      • Could it be a problem with the firmware on the Duet?
      • any other ideas I haven't thought of, yet?
      Thanks, Wilko
        Formatting the card as FAT32 is correct. When you run M122, does the report indicate that the card is detected?
        • wilko
          yes, but the interface speed seems odd (see output below).
          If I remove the card and run M122 again, it says 'SD card 0 not detected, interface speed: 0.2MBytes/sec'.
          If I start the Duet without card and run M122, I get 'SD card 0 not detected, interface speed: 30.0MBytes/sec'.
          Diagnostics
          Used output buffers: 1 of 32 (2 max)
          Platform Diagnostics:
          Memory usage:
          Program static ram used: 13132
          Dynamic ram used: 81780
          Recycled dynamic ram: 3392
          Current stack ram used: 2752
          Maximum stack ram used: 3584
          Never used ram: 29184
          Last reset 00:00:14 ago, cause: power up
          Error status: 0
          Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
          Free file entries: 10
          SD card 0 detected, interface speed: 0.2MBytes/sec
          MCU temperature: min 24.5, current 26.6, max 27.6
          Supply voltage: min 0.4, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0
          Slowest main loop (seconds): 0.000512; fastest: 0.000042
          Move Diagnostics:
          MaxReps: 0, StepErrors: 0\. Underruns: 0
          Heat Diagnostics:
          Bed heater = 0, chamber heater = -1
          GCodes Diagnostics:
          Move available? no
          Stack pointer: 0 of 5
          macro is idle
          http is idle
          telnet is idle
          serial is ready with "M122"
          aux is idle
          file is idle
          Network Diagnostics:
          WiFiServer is disabled
          SPI underruns 0, overruns 0
          Webserver Diagnostics:
          HTTP sessions: 0 of 8
          ok
