    [Solved] Duet Ethernet - DWC consistently loses connection
    Duet Web Control
    • jwgundefined
      jwg
      Duet Ethernet 1.02: DWC connects on startup, and stays connected for about two minutes, or so, then loses connection. This happens whether PC or Mac is connected to network via wireless or wired. Resetting (STOP) the Duet restores the connection for another couple of minutes.
      No other machines lose connection on the network and there are no address conflicts. Interference is unlikely; although, changing the cat5 cable might be worth a try. I'll order one in.
      A connected PanelDue always stays up, but, of course, it's directly wired to the Duet.
      Thoughts?
      • jwgundefined
        jwg
        Looks like a cable issue. Borrowed one from another system, and now DWC stays connected (over the last couple hours). New CAT6 cables on order.
        • T3P3Tonyundefined
          T3P3Tony administrators @jwg
          @jwg thanks for confirming - if it was that please mark this as solved 😄
          www.duet3d.com
