    Not homing correctly
    186
    • foxmike111undefined
      foxmike111
      Hello recently i updated the firmware on my duet maestro 1.0 to 2.03RC5 and when i home the printer sometimes it works and sometimes it doesn't. When it doesnt work it shows the error G0/G1: target position not reachable from current position and the only way to get it to home agin to to do and emergency stop and home it again. Also its a delta. Any idea what this problem is?
      • A Former User?
        A Former User
        Please do share your config.g and homeall.g files
          foxmike111
          ; Configuration file for Duet Maestro (firmware version 2.03)
          ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sun Sep 15 2019 09:51:59 GMT-0400 (Eastern Daylight Time)
          M550 P"3dp" ; set printer name
          M665 R126 L267 B80 H598 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z80.00 E92.60 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X1 Y1 Z1 S1 ; set active high endstops
          M558 P4 H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
          G31 P1000 X0 Y0 Z16 ; set Z probe trigger value, offset and trigger height
          M557 R80 S10 ; define mesh grid
          M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
          M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          ; Custom settings
          M564 H0
          Mine doesnt have a homeall.g file do you want the homedelta.g ???
          • A Former User?
            A Former User @foxmike111
            @foxmike111 said in Not homing correctly:
            oh, yes please, my bad.
            Do you have any deployprobe and retractprobe files as well?
            foxmike111undefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              1.0 to 2.03RC5
              for delta printer you should go with 2.04rc at the moment.
              these are not tuned parameters. please read
              https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
              and save the correct ones
              B4138 is the default and almost certainly wrong for your thermistors. you need to enter the correct value for your thermistor.
              you will need to find the correct offset. Z16 seems to convenient.
                foxmike111
                For my thermistors i use these
                https://www.amazon.com/Anycubic-Thermistor-Wiring-Printer-Heatbed/dp/B01B41K7OM/ref=sr_1_3?keywords=anycubic+NTC+3950+100k&qid=1568564308&sr=8-3
                For the B4138 should it be B3950?
                Ill also switch back to 2.04rc and tune the parameters
                  foxmike111 @A Former User
                  @bearer
                  ; homedelta.g
                  ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sun Sep 15 2019 09:52:00 GMT-0400 (Eastern Daylight Time)
                  G91 ; relative positioning
                  G1 S1 X603 Y603 Z603 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                  G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
                  G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                  G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                  G90 ; absolute positioning
                  G1 X0 Y0 F6000 ; move X+Y to the centre
                  I dont have those files.
                  • Vetiundefined
                    Veti
                    if that is the thermistor that you are using then yes.
                    but only if you have changed the thermistor to this specific one. anycubic uses a lot of different thermistors in their printers.
                      foxmike111 @Veti
                      @Veti
                      Thanks ill change it now.
