Anyone tried Duet on Creality CR-X
Hello
I was wondering if anyone did try the duet on a creality cr-x dual extruder ?
If so how weel do it work ?Mine is allmost stock expect for a bltouch ha been mounted
what problem do you have with your CR-X?
@Veti said in Anyone tried Duet on Creality CR-X:
I was thinking about to update my CR-X with a duet board and later on a pruge bucket so I dont have to use a purge block. I know I also can do that on the stock printer.... But a 32 bit board on the CR-X would be nice
its not much different to the cr10 or the ender 3.
the touchscreen will not work with the duet however.
there is a guide for the ender 3. this should be very similar to your device
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
Okay thanks.... Now I just need to learn the RRF config tool
Maybe I should also update my Ender 3 pro also
Thank you for your input
