    The G29 Mesh does not load well
    • juanmena
      juanmena last edited by
      Good afternoon,
      I have a core XY (Voron 2.1) with a bed of 350x350 mm, and when I print before, I make a G29, but it seems that it does not carry the mesh well, because the nozzle does not stick well throughout the bed. Photo command I am using an original BlTouch.
      The first thing I do is a Macro to start printing.
      I send the files, let's see if there is something wrong.
      The M566 (Which has nothing to do with the error, is it correct, for a good operation or E, should it be faster?)
      Thank you very much in advance.
      CONFIG.G
      ; generated by RepRapFirmware Configuration Tool v2 on Sun Mar 10 2019 17:30:42 GMT+0100 (hora estándar de Europa central)
      M667 S1 ; Select CoreXY mode
      M550 P"Margarita" ; Set machine name
      M552 S1 ; Enable network
      M587 S"i" P"mi***" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M584 X0 Y1 Z5:6:7:8 E3:4:2 ; motor bindings
      M671 X400:400:-50:-50 Y355:-85:-85:355 S5 ; Z drive positions
      M569 P0 S1 ; X motor direction
      M569 P1 S1 ; Y motor direction
      M569 P5 S0 ; Z-- motor direction
      M569 P6 S1 ; Z-+ motor direction
      M569 P7 S0 ; Z++ motor direction
      M569 P8 S1 ; Z+- motor direction
      M569 P3 S1 ; E0 motor direction
      ;M569 P4 S1 ; E1 motor direction
      ;M569 P2 S1 ; E2 motor direction
      M350 X256 Y256 Z256 I0 ; Configure microstepping without interpolation
      M350 E16 I0 ; Configure microstepping with interpolation
      M92 X1280.00 Y1280.00 Z6400.00 E549.00 ; Set steps per mm
      M566 X900.00 Y900.00 Z150.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z1800.00 E6000.00 ; Set maximum speeds (mm/min)
      M201 X3600.00 Y3600.00 Z500.00 E3600.00 ; Set accelerations (mm/s^2)
      M906 X900.00 Y900.00 Z900.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z350 S0 ; Set axis maxima
      ;M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
      M574 X1 Y1 S0
      ;M574 Z1 S0 ; Set active low and disabled endstops
      M98 P"/macros/Zprobe BlTouch"
      M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S150 ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4725 C7.060000e-8 R4700
      M106 P2 C"CAPA" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 T45 H1 C"HOTEND" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F2 ; Define tool 0
      ; Automatic power saving
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;Registro de eventos
      M929 P"registro.txt" S1 ; iniciar el registro en el archivo eventlog.txt
      ; Calibracion de la Temperatura
      M912 P0 S-10
      M572 D0 S0.15
      M501
      MACRO BLTOUCH:
      ; Z-Probe con BLTouch
      M98 P"/macros/Activar EndStop"
      M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 F400 H5 R0.2 T6000 A5 S0.03 ;B1 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X0 Y-26.30 Z1.40 ; Set Z probe trigger value, offset and trigger height
      M557 X50:300 Y50:300 S20 ; Define mesh grid
      MACRO INICIAR IMPRESION:
      ;M98 P"/macros/Iniciar Impresion" ; Cargar Parametros de la malla
      M561
      G29 S2
      M280 P7 S160; Liberación de alarma BLTouch
      G4 P100; retraso para BLTouch
      M98 P"/sys/homeall.g"
      G1 X175 Y175 F12000
      G30
      G32
      G1 X175 Y175 F12000
      G30
      G1 Z10 F36000
      G29
      Thank you.
      Phaedrux 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @juanmena last edited by
        @juanmena said in The G29 Mesh does not load well:
        M561
        G29 S2
        G1 X175 Y175 F12000
        G30
        G32
        G1 X175 Y175 F12000
        G30
        G1 Z10 F36000
        G29
        This is really confusing.
        You're loading a saved mesh, but then later you're doing another probe routine.
        You're doing a homeall and then a G32, and then another G30.
        What is in your homeall.g? What is in bed.g?
          M558 P9 F400
          The dive speed of the probing is quite fast. The BLTouch works best with a slower probe speed for best repeatability. Try F120.
          • juanmena
            juanmena last edited by juanmena
            bed.g
            ; bed.g
            ; generated by RepRapFirmware Configuration Tool v2 on Tue Apr 23 2019 16:30:59 GMT+0200 (hora de verano de Europa central)
            M401
            G30 P0 X25 Y35 H0 Z-99999
            G30 P1 X25 Y310 H0 Z-99999
            G30 P2 X325 Y310 H0 Z-99999
            G30 P3 X325 Y35 H0 Z-99999 S4
            ; Homez.g
            M98 P"0:/macros/Zprobe BlTouch"
            G91
            G1 Z10 F6000 S2 ; lift Z relative to current position
            G90
            G1 X175 Y175 F12000 ;Posiciona en el centro
            M280 P7 S10
            G30 ; Do a single probe to home our Z axis
            G90 ; Make sure we are in absolute mode
            G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
            juanmena Phaedrux 2 Replies Last reply Reply Quote 0
            • juanmena
              juanmena @juanmena last edited by
              This post is deleted!
                M280 P7 S10
                You don't need to manually control the BLTouch pin. It will deploy as needed. So you can remove those M280 commands from your files.
                The bed.g you have configured is using the old plane for of bed compensation. It is redundant since you are using G29 for mesh bed compensation already. So I think you can just remove the G32 or alter the bed.g to use the independent Z motor leveling.
                So before a print all you have to do is
                G28 ; home all axis
                G29 ; mesh compensation probe routine if you want to probe before every print
                Or G29 S1 ; load previously saved mesh map
                • juanmena
                  Thank you.
                  I will try it and tomorrow I comment the results.
                  Thank you
