Need to insert new driver in CoreNG/driver
  • Hi, I am quite new to eclipse. In my project, I am using duet 2 wifi with CAN communication for that I have added can.h and can.c in CoreNG\asf\sam\drivers\can which is compatible with SAM4E8E. But when I build CoreNG with Build Configuration SAM4E8E_RTOS 'can' drivers don't appear in driver list in eclipse. Is there any file in which I need to add any kind of header so that when I build SAM4E8E_RTOS of CoreNG so that 'can' drivers also get compile.
    If you are trying to use the new RRF3 CAN code on Duet 2, forget it. The SAM4E8E only supports basic CAN, not CAN-FD. There are big differences, in particular CAN supports a maximum of 8 bytes per packet, but CAN-FD supports 64.
    PS - to get Eclipse to compile files that you added outside of Eclipse, right click on the project in Eclipse and click Refresh.
  • Yes, refreshing eclipse solved my problem. I am trying to use basic CAN communication with SAM4E8E. Thanks a lot.
