Mid-print Disconnect- Error Bad Command & Misc. Character
Hey all,
So our large CNC converted 3D printer has been doing fine, until this last print where it stopped mid print, then moved itself to a seemingly random location (seen in the machine status bar of the screen shot)- it didn't home, and its not in the code to go to that location. Attached is the "bad command" error it spit out but we have no idea what it means. Any clues?
For now I'll try another print and update this post with how it goes, but any input would be greatly appreciated.
*bad command codes also attached as .txt file
Was this a print form SD card? If so, I suggest you download the file back to the PC and compare it with the original.
This post is deleted!
Was the upload of the file done while a print operation was in progress?
