    My printer is crazy
    • Michael Subergundefined
      Michael Suberg
      After felt 10 rolls of filament my printer starts to do strange things.
      After the temperatures are reached, homing begins. The Y-axis moves normally to the limit switch and the X-axis literally creeps there (very slowly). Then the print head moves in the middle and Z-homing starts. Now the pressure starts in the middle and sometimes by a few centimeters next to it.
      The printof the part is absolutely normal. The X. axis also moves at normal speed.
      At the end of the print, however, the bed moves to the print head and crushes the finished print part.
      Can someone help me?
      Firmware 2.02 (RTOS)
      WIFI Server Version 1.22
      Web Interface 1.22.6
      Config.g :
      ; generated by RepRapFirmware Configuration Tool v2 on Sun Dec 02 2018 19:51:47 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Subis X400" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M584 X0 Y2 Z1 E3 ; Apply custom drive mapping
      M92 X66.66 Y66.66 Z2400.00 E492.0 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X5000.00 Y5000.00 Z220.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1400.00 E1200.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X390 Y390 Z340 S0 ; Set axis maxima
      M574 X2 Y2 Z0 S1 ; Set active high endstops
      M558 P1 H4 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
      G31 P500 X35 Y10 Z1.8 ; Set Z probe trigger value, offset and trigger height
      M557 X30:370 Y30:390 S40 ; Define mesh grid
      M305 P1 X200 ; Set thermistor + ADC parameters for heater 1
      M106 P0 H-1 ; Set fan 0 value, PWM signal Thermostatic control is turned off
      M106 P2 T45 H1 ; Set fan 1 value, Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; M557 X10:300 Y10:300 S25
      • Vetiundefined
        Veti
        please post the end of a g code file where the crushing has occured
          Michael Suberg
          problem found, cable from the limit switch is broken, therefore wrong switching states to the controller.
