SOLVED PanelDue no longer works after an update?
As I suspected ... my PanelDue i7 does not work after an update!
I was in 1.17 and I wanted to pass in 1.23.2 ...
After battling with Bossa 1.9.1, which by default is not compatible on Mac OS. I had to recompile a dynamic library for Bossa to finally open!
After having followed the procedure here https://miscsolutions.wordpress.com/paneldue/ which has apparently taken place normally, I find myself with a screen with vertical lines on my screen ... Moreover, Erase and Reset do not seem to work anymore on my PanelDue i7
A little, help ... Thank you
Well ... I answer myself!
I just forgot to check the box "Boot to flash" in Bossa!
My Paneldue has been updated !!!
