question about extrusion factors in dwc
hi all, something im not sure about, is the extrusion factor in wdc is what is the shown numbers a ratio of?i have set in my config, m221 s80. so would 100% in wdc be 100 percent of 80 or does it disregard it
thank you
The extrusion slider in DWC and M221 are one and the same.
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_Speed_and_Extrusion_Factors
https://duet3d.dozuki.com/Wiki/Gcode#Section_M221_Set_extrude_factor_override_percentage
