    Duet3: Loading config.g after upload
    Beta Firmware
    • evan38109undefined
      evan38109
      I'm sure this is an extra dumb question coming from a newbie to the Duet ecosystem, but I've spent an hour on it now and I'm stumped.
      After uploading config.g and related files, how do you get the Duet 3 to load them?
      I've:
      1. Followed the instructions in the SBC Setup Guide. No problems, the Pi4 and Duet3 are working fine.
      2. Created config files with the Config tool, then adapted them with the instructions in the RRF3 Overview.
      3. Uploaded them via the web UI's System tab, as instructed in the SBC Setup Guide's section on Configuring System Files:
      Is there a GCode or some such I need to run or option in the Web UI I need to run to execute the config.g file? I've even tried rebooting several times (shutdown -r now, via SSH) with no luck. The Console tab is empty save for one entry that reads, "Connected to duet3."
      If it helps, my config.g is here. (Disclaimer: It's a first pass, I'm a newbie to RRF, and there are probably issues.)
      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Sep 21 2019 18:19:31 GMT-0500 (Central Daylight Time)
      G90                                       ; send absolute coordinates...
      M83                                       ; ...but relative extruder moves
      M550 P"Duet3"                             ; set printer name
      ; M552 S0                                   ; disable network
      M569 P0 S1                                ; physical drive 0 goes forwards
      M569 P1 S1                                ; physical drive 1 goes forwards
      M569 P2 S1                                ; physical drive 2 goes forwards
      M569 P3 S1                                ; physical drive 3 goes forwards
      M569 P4 S0                                ; physical drive 4 goes backwards
      M584 X0 Y1 Z2:3 E4                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                   ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z400.00 E980.00       ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E240.00       ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z720.00 E7200.00 ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z200.00 E5000.00   ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z600 E1050 I50           ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                   ; Set idle timeout
      M208 X0 Y6.2 Z0 S1                        ; set axis minima
      M208 X255 Y218.7 Z210 S0                  ; set axis maxima
      M574 X1 Y1 S3                             ; set endstops controlled by motor stall detection
      M574 Z1 S2                                ; set endstops controlled by probe
      M558 P5 H5 F300 T6000                     ; set Z probe type to switch and the dive height + speeds
      G31 P500 X-20 Y10 Z1.54                   ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y21.2:195 S20                ; define mesh grid
      ; - Bed Heater
      M308 S0 A"BedTemp" P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ; define bed temperature sensor
      M950 H0 C"out9" T0 Q10                    ; heater 0 uses the out_9 pin, sensor 0, low PWM freq because it's a SSR (Can we use bang-bang mode?)
      M143 H0 S125                              ; set temperature limit for heater 0 to 125C
      ; - E0 Heater
      M308 S1 A"ExtruderTemp" P"temp1" Y"thermistor" T100000 B4092 R4700 ; define E0 temperature sensor
      M950 H1 C"out0" T1 Q100                   ; heater 1 uses the high current output pin, sensor 1
      M143 H1 S300                              ; set temperature limit for heater 1 to 300C
      ; F0 - Part Cooling Fan
      M950 F0 C"out4+out4.tach" Q500      ; Part cooling fan F0 is three-wire fan with tacho on out4
      M106 P0 C"Part" S0 H-1              ; Name the fan. No thermostatic control.
      ; F1 - Extruder Fan
      M950 F1 C"out5+out5.tach" Q500      ; Extruder fan F1 is a three-wire fan with tacho on out5
      M106 P1 C"Extruder" S1 H1 T45       ; Name the fan. Thermostatic control is turned on.
      ; F2 - Case Fan
      M950 F2 C"!out6+out6.tach" Q25000   ; Case fan F2 is a four-wire PWM fan with tacho on out6
      M106 P2 C"Case" S0.5 H-1            ; Name the fan. No thermostatic control. Start at half speed.
      ; F3 - Pi Fan
      M950 F3 C"out7" Q500                ; Pi fan F3 is a three-wire PWM fan (but we're out of tacho inputs) on out7
      M106 P3 C"Pi" S0.5 H-1              ; Name the fan. No thermostatic control. Start at half speed.
      M563 P0 S"Extruder" D0 H0 F0              ; define tool 0
      G10 P0 X0 Y0 Z0                           ; set tool 0 axis offsets
      G10 P0 R0 S0                              ; set initial tool 0 active and standby temperatures to 0C
      • Danalundefined
        Danal
        Boot (the Duet, not the Pi).
        Enter M999 into either of the DWC (Duet Web Console) command areas. Or power cycle.
        There is a small advantage by going to the DWC "console" function and entering M999 there. This allows you to see the error messages from your config.g (if any), when DWC re-connects.
          evan38109
          Ahh, that's what I was missing. Thank you!
