    SOLVED Updating Firmware on Duet 3?
    Beta Firmware
    8
    16
    812
    • JuKu
      JuKu last edited by
      I have Duet 3 board, which I run in standalone mode. I can connect to it using the Web interface version 1.22.6; content of the www directory is from Duet 2 SD card. I'd like to use the latest firmware, so I try to update:
      I downloaded the file Duet3iap_sd_MB6HC.bin to sys.
      (At https://github.com/dc42/RepRapFirmware/releases/tag/3.0beta10 it says "Duet3iap_sd_MB6HC.bin is the IAP file for Duet 3 production main boards running in standalone mode (without a connected RPi), used when updating firmware via DuetWebControl served from the local Ethernet port").
      I then get file Duet3Firmware_MB6HC.bin from the above page, and download it to the board. I get prompted "You have just uploaded a firmware file. Would you like to update your Duet now?". I click Yes. The response is: "M997 S0 Error: Firmware binary "Duet3Firmware_MB6HC.bin" not found". The sys folder
      gets a file named "Duet3Firmware.bin".
      What am I doing wrong?
      • Danal
        Danal last edited by Danal
        You shouldn't need to reload the IAP file. They change very infrequently. I have not reloaded mine (as vs. the base image file that Duet provides for the SD). I would remove the Duet3iap_sd_MB6HC.bin from sys, and try again.
        All file names SHOULD be handled correctly. I've done an upgrade with the Duet3Firmware_MB6HC.bin from that link, via DWC, and I don't remember anything odd about it.
        Nonetheless, if nothing else works, put the Duet3Firmware_MB6HC.bin file in 0:/sys yourself and issue "M997 S0" manually.
        Let us know.
        JuKu 1 Reply Last reply Reply Quote 0
        • Danal
          And, if all else fails, format a fresh SD (not quick format), FAT32, and then image it per the instructions (and image) found here
          Then do the upgrade via DWC.
          That's the path I followed, and it worked.
          Of course, keep any files like config.g, or whatever, in which you've invested work!!
          • JuKu
            JuKu @Danal last edited by
            Thank you! The problem is/was that the download renamed the file "Duet3Firmware_MB6HC.bin" to "Duet3Firmware.bin", yet the M997 command wanted "Duet3Firmware_MB6HC.bin". I renamed it back, and then manually issued "M997 S0". This worked.
            Btw, DWC reports the firmware version as "3.0beta10 (2019-09-12b1)", yet people refer the newest version as 1.0.4.0. ?
            • jannau
              jannau last edited by
              1.0.4.0 is the current version of DuetSoftwareFramework, the software running on the SBC in the non-standalone mode.
                dc42 administrators @JuKu last edited by
                @JuKu said in Updating Firmware on Duet 3?:
                Old versions of DWC do this renaming because they don't know about the new naming convention for RRF on Duet 3. So you need to upload the firmware file, decline the invitation to install it, then send M997.
                Btw I find that the IAP for Duet 3 isn't yet 100% reliable, so sometimes I have to resort to USB and Bossa.
                • gtj0
                  gtj0 last edited by
                  USB and Bossa seems to be the only way that works with the current versions of the DSF and firmware. When you execute M997, you get
                  M997 S0
                  Error: Failed to find IAP file /opt/dsf/sd/sys/Duet3iap_spi_MB6HC.bin
                  Duet3iap_spi_MB6HC.bin isn't in the distribution.
                  dc42 wilriker 2 Replies Last reply Reply Quote 0
                  • A Former User
                    A Former User last edited by
                    Pretty simple to use usb and bossa with M999 PERASE, no need to manually use the erase jumper. But ofc DWC is even simpler 👍
                      dc42 administrators @gtj0 last edited by
                      @gtj0 said in Updating Firmware on Duet 3?:
                      M997 S0
                      That file should be included. I'll follow that up.
                      brendon 1 Reply Last reply Reply Quote 1
                      • wilriker
                        wilriker Moderator @gtj0 last edited by wilriker
                        This file together with some others has been moved from duetsd to the new additional package reprapfirmware. It seems that documentation has not yet caught up.
                        Manuel
                        My Tool Collection
                        gtj0 1 Reply Last reply Reply Quote 0
                        • gtj0
                          gtj0 @wilriker last edited by
                          @wilriker said in Updating Firmware on Duet 3?:
                          I see the deb package added in DSF but I'm not seeing the bin file nor any means to create it.
                          wilriker 1 Reply Last reply Reply Quote 0
                          • wilriker
                            @gtj0 AFAIK it's auto-generated by a filesystem watchdog on the package server.
                            Manuel
                            My Tool Collection
                            • gtj0
                              gtj0 last edited by
                              Well that's not too open-source friendly.
                              • brendon
                                brendon @dc42 last edited by
                                @dc42 said in Updating Firmware on Duet 3?:
                                Any update on this file?
                                Current Duet3 version:
                                RepRapFirmware for Duet 3 MB6HC 3.4.0 beta 6 (2021-11-06)
                                Duet Web Control 3.4.0-b6
                                • A Former User
                                  @brendon
                                  apt said
                                  pi@duet3:~ $ sudo apt-get upgrade
                                  The following packages have been kept back:
                                    duetsoftwareframework
                                  so i said
                                  pi@duet3:~ $ sudo apt-get upgrade duetsoftwareframework
                                  Reading package lists... Done
                                  Building dependency tree
                                  Reading state information... Done
                                  Calculating upgrade... Done
                                  The following NEW packages will be installed:
                                    reprapfirmware
                                    libgl1-mesa-dri mesa-va-drivers mesa-vdpau-drivers
                                  The following packages will be upgraded:
                                  1 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
                                  Need to get 433 kB of archives.
                                  After this operation, 0 B of additional disk space will be used.
                                  Do you want to continue? [Y/n] y
                                  Get:1 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 1.1.0.1-1 [431 kB]
                                  Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 1.1.0.1 [1,706 B]
                                  Fetched 433 kB in 1s (520 kB/s)
                                  Reading changelogs... Done
                                  Selecting previously unselected package reprapfirmware.
                                  (Reading database ... 75827 files and directories currently installed.)
                                  Preparing to unpack .../reprapfirmware_1.1.0.1-1_all.deb ...
                                  Unpacking reprapfirmware (1.1.0.1-1) ...
                                  Preparing to unpack .../duetsoftwareframework_1.1.0.1_armhf.deb ...
                                  Unpacking duetsoftwareframework (1.1.0.1) over (1.0.3.3) ...
                                  Setting up reprapfirmware (1.1.0.1-1) ...
                                  Sending update request to DCS... Done!
                                  Setting up duetsoftwareframework (1.1.0.1) ...
                                  pi@duet3:~ $ echo M115 | sudo /opt/dsf/bin/CodeConsole
                                  Connected!
                                  FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.5 FIRMWARE_VERSION: 3.0beta10+2 ELECTRONICS: Duet 3 prototype v0.5 FIRMWARE_DATE: 2019-09-28b1
                                  pi@duet3: $ ls /opt/dsf/sd/sys
                                  config.g                  Duet3Firmware_TOOL1LC_11.bin  Duet3iap_spi_MBP05.bin
                                  Duet3Firmware_EXP3HC.bin  Duet3Firmware_TOOL1LC.bin     dwc2settings.json
                                  Duet3Firmware_MB6HC.bin   Duet3iap_sd_MB6HC.bin
                                  Duet3Firmware_MBP05.bin   Duet3iap_spi_MB6HC.bin
                                  which seems to have sorted it out and upgraded the firmware all one go
                                  • brendon
                                    brendon last edited by
                                    Interesting, I didn't see the The following packages have been kept back: message. I ran the suggested code and it looks like the firmware is all up to date! Thanks for the support!!!
