    WiFi
    • Mikesplane
      Mikesplane last edited by
      Like others I am not good with electric bits, can I put my Duet board under my Kossel delta mini or will the frame stop the signal? Or is there a way to extend the antenna?
      Mike
        I have the Duet underneath my Kossel with the wifi antenna protruding slightly. If the wifi signal is reasonably strong in the room where the printer will be, then it should be OK to put the Duet underneath the bed, assuming it is not surrounded by a solid metal frame. There is no easy way of extending the antenna, and FCC/CE regulations make it impractical for us to offer a version with an external antenna.
