My CNC duet 3 experience
I have finally managed to get my Workbee homing properly. I have had a number of issues mainly due to typographical errors in the config.g file. The only way I have been able to track them down is using the program opt/dsf/bin/DuetControlServer as usually the problem has been the duetcontrolserver crashes. The last unsolved error is from the line:-
M581 X S-1 T0 C0 ; disable trigger for endstop X
and the error is missing parameter T. However it doesn't prevent the homing operation.
I have found that the Raspberry Pi gets very hot without a fan and I have had low voltage errors although they haven't affected operation.
Finally I need a box with fans to put this in so I hope someone will one in the near future
