    Editing files in /sys/subdirectory???
    Duet Web Control
    70
    • GeorgeM
      GeorgeM last edited by
      Since I am using my machine for both printing and laser engraving, I am making use of the M505 command to use alternate configuration files. However it seems like I cannot edit the files in the directory under the sys directory. I have to put the card in my computer to edit them. Is there something I am missing or is that a request that should go in for an enhancement?
      T3P3Tony Dougal1957 Danal 3 Replies Last reply Reply Quote 0
      • Danal
        Danal last edited by
        Duet Web Control does not support editing arbitrary files in arbitrary directories.
        You can turn on FTP and transfer/edit/transfer anything anywhere on the SD. When FTP is on, so is SFTP and some editors will use (one of these) to make it fairly seamless. Many people do this simply to use an "editor of choice" instead of the primitive edit capability build into DWC.
        Make sense?
        • T3P3Tony
          T3P3Tony administrators @GeorgeM last edited by T3P3Tony
          @GeorgeM
          On 1.X versions of DWC this is not available as far as I remember
          On 2.X version go to system and the option to make and enter directories should work
          Duet Hardware Designer
          www.duet3d.com
          • Dougal1957
            Dougal1957 @GeorgeM last edited by Dougal1957
            @GeorgeM said in Editing files in /sys/subdirectory???:
            It works for me on the latest system Not tried it on v2 system tho
            Just tested on V2 of DWC and it works ok there as well
            • Danal
              Danal @GeorgeM last edited by Danal
              @T3P3Tony said in Editing files in /sys/subdirectory???:
              go to system and the files are there
              Tony, I don't believe that DWC supports editing files in sub directories under /sys
              • Dougal1957
                Dougal1957 last edited by Dougal1957
                DWC V2.x certainly supports having the directories and contents but what it will do with them I am not sure
                Danal 1 Reply Last reply Reply Quote 0
                • Danal
                  Danal @Dougal1957 last edited by
                  @Dougal1957 said in Editing files in /sys/subdirectory???:
                  Having them, yes. Editing files in them??
                  Dougal1957 1 Reply Last reply Reply Quote 0
                  • Dougal1957
                    Dougal1957 @Danal last edited by
                    @Danal said in Editing files in /sys/subdirectory???:
                    Yes I can edit them as well!
                    • Danal
                      Yep, just answered my own question. Web 1.x doesn't let you, Web 2.x does. Thanks @Dougal1957 !!
                      Latest repository: https://github.com/chrishamm/DuetWebControl check under "releases".
                      GeorgeM 1 Reply Last reply Reply Quote 0
                      • GeorgeM
                        GeorgeM @Danal last edited by
                        @Danal Is "package.json" the file I should dl?
                        • T3P3Tony
                          @GeorgeM go to:
                          https://github.com/chrishamm/DuetWebControl/releases
                          and grab the appropriate zip file for your Duet (duet 2 or Duet 3)
                          The contents go in the www directory
                          www.duet3d.com
                          • GeorgeM
                            GeorgeM @T3P3Tony last edited by
                            @T3P3Tony Never mind. I figured it out.
                            • GeorgeM
                              Well I spoke too soon. I dl from here
                              https://github.com/chrishamm/DuetWebControl/tree/next
                              which is the "next" tree of DWC.
                              It downloads a file DuetWebControl-next.zip
                              But when I install this from within DWC 1.22.6 I see it unzipping a lot of files and then a blank screen.
                              I have to copy my backup /www directory onto the card to get back up.
                              Do I have the wrong file?
                              • T3P3Tony
                                @GeorgeM
                                @GeorgeM go to:
                                www.duet3d.com
                                • GeorgeM
                                  @T3P3Tony Thank You. That works.
