crc32appender now needed for RRF?
The Windows version of Eclipse lets you set up the search path within Eclipse. Does the Mac version offer the same?
What does this tool do? I still get the .bin I want.
I get an error when building:
arm-none-eabi-objcopy -O binary "C:\eclipse\Firmware\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.elf" "C:\eclipse\Firmware\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.bin" && crc32appender "C:\eclipse\Firmware\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.bin"
c:/program files/gnu arm eclipse/build tools/2.6-201507152002/bin/sh: crc32appender: not foundBuilding again the error goes away, there is an depency error in the makefiles.
@bondus It adds the CRC32 checksum to the end of the generated binary. The firmware updater checks for that. It will certainly complain if it's wrong but I don't know off hand what it does when it's missing.
The firmware will stop at boot up and flash the Diag LED if the CRC is wrong.
@dc42 that crc protection certainly worked, I had to use SAM-BA to get my board back. It would be nice if the flasher-updater in the firmware also checked the CRC before updating.
@bondus said in crc32appender now needed for RRF?:
Good idea, I'll add this to the work list.
Checking the CRC in the upgrader will limit downgrading though.
And adding the PATH in the dev environment to that tool is missing in the description on how to build the firmware. It's hard enough already to get RRF to build.
I'm having the same problem with crc32appender not being found in Eclipse.
I had to run it manually from the command line after the binary was generated.
Not sure what I need to do to tell Eclipse where to look for the file though.
Oddly enough, the instructions are in BuildInstructions in the dev and v3.01-dev branches but not in the v3-dev branch.
You need to copy the appropriate binary from Tools/crc32appender to someplace in your system PATH or update your system PATH to point to the directory where the appropriate binary is located. If you're on Linux, you can just copy Tools/crc32appender/linux-x86_64/crc32appender to /usr/local/bin.
