    porting rrf firmware to arduino due with ramps
    Firmware developers
    553
    • poohzazaundefined
      poohzaza
      i just wordering if it possiable can port reprap firmware to arudino due to ramps1.6+ with tmc2209 or tmc2130
      as far as i know you just need to change the pin maping and add ethernet moudle to ramps shilds
      DocTruckerundefined Danalundefined 2 Replies Last reply Reply Quote 0
      • DocTruckerundefined
        DocTrucker @poohzaza
        @poohzaza you will need to look into RADDS rather than RAMPS.
        • Vetiundefined
          Veti
          there is a lpc port. https://github.com/sdavi/RepRapFirmware
          • poohzazaundefined
            poohzaza
            @DocTrucker said in porting rrf firmware to arduino due with ramps:
            RADDS
            will it be compatable with tmc 2209 in uart with all of it smartness or the duets wifi is open sorce so i can down load the pcb and mod it to my like so that why i want to try port rrf firmware for my own use
            and RADDS is not avaible for local seller only clone stff are avaible
            DocTruckerundefined 1 Reply Last reply Reply Quote 0
              @poohzaza I'm under the impression RAMPS will kill a duet due to the 5V/3.3V compatibility issues. There due like boards which report compaibility with RAMPS boards but I have not looked into those.
              As for the Due I would investigate ada fruit's grand central.
              • Danalundefined
                Danal @poohzaza
                @poohzaza said in porting rrf firmware to arduino due with ramps:
                If the goal is one of those two drivers, MUCH easier to modify an existing Duet, starting from the KiCad files (which are published) and having it fabbed.
                • poohzazaundefined
                  poohzaza
                  @Danal said in porting rrf firmware to arduino due with ramps:
                  how about firmware supoort for step driver
                  do i have to mod the firmware
                  • Vetiundefined
                    Veti
                    yes at the moment you do. there is no support for tmc2209 at the moment.
                      DocTrucker
                      Have you compared the TMC5160 to the 2209? Since the latter is ran on Duet3 it shouldn't be beyond reasonable possibility to get it running using the step sticks, be it with a 4A limit rather than the Duet3's 6A rating. I'm trying to do that with a the Dev board for the processor that is in the Duet3, but have had to shelve that work while I get my machines fully calibrated.
                        dc42 administrators @DocTrucker
                        The concept tool board that we demonstrated at TCT uses a TMC2209. Our existing TMC22xx driver controls it, and apart from not supporting stall detection, works fine. We'll add stall detection to that driver in due course.
