    Can I use the Z-axis stepper driver for my X-axis?
    • Grudairianundefined
      Grudairian
      I just picked up a used Folgertech FT6 CoreXY printer, and I have been so impressed with my last duet wifi that I want to swap out the controller on this board too. The FT6 uses a single Z-axis motor and two separate stepper motors for the X-axis. I was wondering if I would be able to remap the z-axis output and x-axis output from the board? Normally I would just think about using the spare Stepper driver, but this particular model came with dual extruders, so I am pretty much out of stepper drivers other wise.
      • fcwiltundefined
        fcwilt
        You should be able to that.
        Are you wanting to do that because of the dual connectors for the Z axis?
        • Vetiundefined
          Veti
          driver remapping is done via the M584 command.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
          be aware of the command order.
          also the z steppers connectors are in series (halfs voltage).
          you could try assigning the e1 as the second x motor.
            Grudairian
            @fcwilt Yes, the dual connectors for the Z-Axis would be great as there are two X-axis Steppers that need to be driven in unison.
            @Veti Thanks for the heads up about the z-steppers only getting half voltage each. Do you know if that affects what I should set my esteps or Motor current too? I was just planning to run them at 70% of their rated current. As for the e1 output, I still need that for my second extruder, so it's not a great option right now unfortunately.
            • Vetiundefined
              Veti
              @Grudairian said in Can I use the Z-axis stepper driver for my X-axis?:
              it does not affect the esteps or the current.
              if they are run in parallel it would half the current but keep the voltage the same.
