    Print Quality - Gaps at beginning of outer skin
    3D Printing General Chat
    • nbGUundefined
      nbGU
      I've been trying to solve this problem for weeks and i'm at a loss with it. My extruder doesn't start laying down material until its 5mm into the outer skin layer but interestingly this problem doesn't appear on smaller printed parts (see images)
      ![1_1570344738137_20191006_074531.jpg](Uploading 100%) ![0_1570344738135_20191006_074526.jpg](Uploading 100%)
      <blockquote class="imgur-embed-pub" lang="en" data-id="a/MhbJ1wk" data-context="false" ><a href="//imgur.com/a/MhbJ1wk"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
      I'm slicing the model in Cura, the print shown is PLA printed at 200 Celsius with:
      • no retraction
      • no coasting
      • no outer wall wipe
      • Z seam aligned to sharpest corner
      • e3d titan aero on a cartesian machine
      • No pressure advance from the Duet
      • No fancy settings in Cura (like equalize filament flow, though i have tried it with no improvement)
      I've played with acceleration, jerk and speed in my Duet 2, settings are currently a conservative:
      Jerk: X 500, Y 500, E 1200 (mm/min)
      Accel: X 800, Y 800, E1200 (mm/min)
      Max speed: set high but in slicer i've printed between 40 and 90mm/s with travels between 90 and 160mm/s
      My extruder is calibrated but i've experimented with increased extrusion multipliers to the point of obvious over extrusion and the problem still persists.
      Like i say on smaller prints the problem is non existent, i get a near perfect Benchy print with 0.6mm retraction, 0.1 outer wall wipe and at jerk and acceleration 50% higher than what i've currently dialled back to.
      Can anyone make suggestions to what you think might be the cause of the problem?
      • burtoogleundefined
        burtoogle
        Two settings you don't mention but are worth trying are to set combing to "no-skin" and the max comb distance with no retract to something like 10 or 20.
        • Vetiundefined
          Veti
          @nbGU said in Print Quality - Gaps at beginning of outer skin:
          no retraction
          why are you printing with no retractions?
          nbGUundefined 1 Reply Last reply Reply Quote 0
          • nbGUundefined
            nbGU @Veti
            I normally print with 0.4mm retraction on small prints and get great results. I tried no retraction to try to solve this problem.
            I switched to a default Cura profile today and my issue entirely went away, haven't gone through and figured out which setting was causing the problem yet though.
