Z motor Tries To Pass Endstop
I'm having an issue where when I'm trying to home the axis the Z-axis hits the end stop and keeps going. I don't know if this is because I have a BLTouch installed as well and have no calibrated it yet (which it won't let me do until I home all axis). Any help would be appreciated.
Do you have the end stop switch configured to be the end stop for the Z axis AND is it on the correct end?
Some folks use their Z-probe as a "end stop switch", so to speak, and home using that.
I have a BLTouch Z-probe but I saw no reason to remove my existing Z axis end stop switch and I continue to use it for Z axis homing.
The BLTouch in this case is only used for probing.
It all works fine.
This post is deleted!
@fcwilt How can I check to make sure I have the switch set as the end stop? Sorry for the bother, I'm new to all this!
@AlexTheGreat said in Z motor Tries To Pass Endstop:
Check your config file for a M574 command with a Z0 or Z1 or Z2 parameter.
The Z parameter specifies the location of the "endstop switch":
- Z0 means there is not Z endstop switch
- Z1 means the Z endstop switch is at the "low" end of the axis (near the axis minimum)
- Z2 means the Z endstop switch is at the "high" end of the axis (near the axis maximum)
There should also be a S parameter which specifies the type of endstop device:
- S0 means the endstop input will respond to an active low condition
- S1 means the endstop input will respond to an active high condition
- S2 means the Z-probe is to be used for "endstop" detection.
- S3 means stepper motor load detection is to be used for "endstop" detection.
There is quite a bit of documentation that may help you along.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_filesPlease post your config.g and homing files.
