    Optical end stop PNP
    • likevviiundefined
      likevvii
      I have optical endstops that I want to use in my machine for X and Y.
      My board is duet2wifi
      They are PNP type, and are sourcing 5V when triggered. (Omron EE-SX670R - PNP type)
      http://www.ia.omron.com/data_pdf/cat/ee-sx47_67_ds_e_13_2_csm483.pdf
      As far as I know, the duet works with NPN/sinking type switches. Is there a way to make my PNP switches work?
      Random side question, what is the difference between open-collector and line driver?
        As you suggest, NPN types would be more suitable. This PNP switches might work if you connect a load resistor of about 330 ohms between output and ground. If that doesn't work, then a higher value load resistor (e.g. 10K) followed by a 2N7000 mosfet would work.
