Cooling fan weirdness
  • I have three fans on my printer with a duet wifi. Hotend fan, case fan and part cooling blower. All was working well but then I noticed print issues that looked like it was a part cooling issue.
    On further investigation I noticed that during a print the part cooling fan was not spinning.
    As soon as I cancel the print the part cooling fan starts to spin. With the panel duo I can speed the fan up and slow it down. However as soon as a print job starts the fan stops.
    I have checked my slicer (prusa slicer) and the cooling is set to always on and enable auto cooling with a minimum of 35% and a max of 100%.
    When printing the panel duo shows the fan should be spinning but the fan is completely off.
    This is my fan config;
    M106 P0 S0 I1 F25000 H-1
    M106 P1 S1 I1 F25000 H1 T45
    M106 P2 S1 I0 F25000 H1 T45
    Any idea where to look?
  • Seems to have sorted itself. I disconnected then reconnected the fan and its working how it should again.
