    Duetwifi w/ BLtouch
    My Duet controlled machine
    • idaho creator
      idaho creator last edited by
      I started off with an Anet A8 Prusa Clone. Soon fried the stepper motor drives on it. So I decide I was going to upgrade but was tired of Chinese junk. I almost went with the Smoothie board but found the Duetwifi much more to my taste. I am currently converting the Anet into a larger printer 300x300x450 print area using 2020 profile and my 12u server case that is my current 3d printer housing. I have liked using the Duetwifi for the ability to modify the software as I haven't written code since my C64 and Basic. I think I have learned more from this board than the build and play Anet A8 board and this forum. The people here are also much nicer.
      • andjan1964
        andjan1964 last edited by
        Hello đŸ™‚
        I am going the same way from Anet A8 with BLtouch to Duet wifi
        will you share the files/setup i need to set it up ?
        my Duet wifi card is on the way to me đŸ™‚
        Aluframe AM8 rezized
        My bed is X370 Y370 Z420
        Cilicone heater 800W 220V AC
        Jan Erik
        • FrankNPrinter
          FrankNPrinter last edited by
          check the forum, several have documented all the little quirks of the bl touch models and how to get around them. Whitewolf and CAlvinX are pretty much subject matter experts as far as i am concerned…
