Cabinet Heater Control
Hi, first post so be gentle
By way of some background, I have recently converted a Tevo Black Widow to Duet Maestro and am very happy with the improvements. The printer is heavily modified from stock with linear rails, H carriage bearings, E3D Titan Aero and custom CFNylon Hardware.
This particular printer lives in a custom MDF enclosure in the garage. The enclosure has a 240v 1500w IR heater driven off an SSR by the Duet using BangBang Control. The issue I have is once I am up to temp (60c) the maintenance of the temperature by the controller is quite rapid, i.e, it will flash the heater on and off quite quickly.
The question I have is.... Is there a way to reduce the frequency of the temperature maintenance or extend the acceptable degrees variance in temperature.
eg, currently its maintaining 60c +/- 0.2c whereas if I could maintain 60c +/- 2c it would be on and off less frequently and for longer periods of time whcih would better prolong the life of the bulbs.
Any thoughts?
Thanks
Jay -
Switch from bang bang to PID. You can alter the PWM frequency as well if it's still too rapid.
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_a_chamber_heater
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
