    Duet2 wifi mac address
    My Duet controlled machine
    • dmtulsaundefined
      dmtulsa
      I know it states "The default MAC address on a Duet 2 Ethernet is generated from the unique processor ID so there is normally no need to change it." But I need the mac address to set up a static rout in my router. I've used wifi sniffers but none see the printer. How should I go about getting the mac address?
      Thank you
      Doug
      • Vetiundefined
        Veti
        normally the router has a page that shows a list of dynamic ip addresses assigned by dhcp. there normally the mac address is listed.
        or look for an entry for arp routing table in the router.
        • A Former User?
          A Former User
          @dmtulsa said in Duet2 wifi mac address:
          i believe its part of the output from M122 on a duet wifi, but as stated its usually listed in the router somewhere, or even on your local computer by displaying the arp table. (arp -aon windows command line)
            droftarts administrators
            Yes, M122 shows it in the Network section:
            === Network ===
            Slowest loop: 15.41ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is running
            WiFi firmware version 1.23
            WiFi MAC address 5c:cf:7f:1a:9c:3b
            WiFi Vcc 3.34, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24992
            WiFi IP address 192.168.0.4
            WiFi signal strength -64dBm, reconnections 0, sleep mode modem
            • dmtulsaundefined
              dmtulsa
              Okay thank you all very much, that did it.
              Doug
