RepRapFirmware 2.04 released
Finally, RRF 2.04 is released at https://github.com/dc42/RepRapFirmware/releases/tag/2.04. I intend this to be the last release in the RepRapFirmware 2 series, because development has now moved to RRF 3.
There have been only minor changes since the 2.04RC4 release, of which the most significant one is fixing a bug that caused file uploads over HTTP to fail sometimes because of spurious mismatched CRC messages.
Please note, I do not test the firmware builds for Duet06/085 or RADDS electronics. So use these with even greater care than usual.
@fcwilt said in RepRapFirmware 2.04 released:
Thanks.
Will you be fixing problems that may be found in the release?
Maybe, depending on how serious they are and when RRF3 is ready for general release.
@dc42 said in RepRapFirmware 2.04 released:
Based on your progress to date with RRF3 do you have a rough idea (very rough) of when RC1 will be ready?
Thanks.
Thanks.
Maybe around Christmas, maybe January.
Thanks.
I just hope that when the time arrives that RRF2 users have no other choice other than to upgrade to RRF3 that the upgrade documentation is upgraded as well to a standard where your ordinary joe blogs can understand it.
@chas2706 said in RepRapFirmware 2.04 released:
its not that much different. you just have to specify which pins to use for endstops etc.
the configurator can now generate rrf3 configs
https://configtool.reprapfirmware.org/Start
@Veti Ok thanks I will take a look for future reference.
We are in the process of updating all the documentation to cover RRF3.
Great, Thanks.
