    Help: NEMA 23 High-Torque Stepper Motors
    • TLAS
      TLAS last edited by
      Looking for some help with a rather unusual problem - I'm using fairly large stepper motors, and I'm currently unable to get them to work.
      The motors I'm using are at the following page:
      https://www.automationtechnologiesinc.com/products-page/nema-23/kl23h286-20-8b/
      I've wired the motors in the bipolar parallel configuration according to the diagram. I used A1 as Positive and A2 as negative, similar for B. When I start to home the unit, the motors jerk like they're about to move, but then cut out. I can move them by hand afterward, so I know they aren't idling. I plugged them into the extruder driver and I notice the same behavior - but it will only make a jerk and refuse to move (only the first time I try, thereafter there is no movement until I reset the unit).
      I've plugged in a regular nema 17 in and it will run fine off of the drivers.
      Any suggestions? Here's some of my settings below:
      M92 X40 Y40 Z40 ; Set axis steps/mm
      M906 X2000 Y2000 Z2000 E2000 I60 ; Set motor currents (mA) and increase idle current to 60%
      M201 X50 Y50 Z50 E500 ; Accelerations (mm/s^2)
      M203 X1000 Y1000 Z1000 E3600 ; Maximum speeds (mm/min)
      M566 X500 Y500 Z500 E1200 ; Maximum instant speed changes mm/minute
      My best guess is that I'm triggering some kind of short in the driver. It has the same behavior no matter the motor current (Even 1 mA). I believe I'm running 1.14ish of the firmware. I have a 24V power supply.
      • fcwilt
        fcwilt last edited by
        Try spec'ing a lower current as a test.
        Have you read this?
        https://duet3d.com/wiki/Choosing_stepper_motors
        • TLAS
          TLAS last edited by
          I may have found the problem… whomever developed the 1A 1B 2A 2B notation on drivers (vs A+ A-, B+ B-) deserves to be shot...
          https://groups.google.com/forum/m/#!topic/ultimaker/zdIKGwMXf28
          • TLAS
            TLAS last edited by
            Yeah, that was problem… grumble grumble grumble
