    Strange homing behavior in all betas.
    Beta Firmware
    • Nuramoriundefined
      Nuramori
      I noticed a strange behavior while homing, and I checked it through the last several revisions.
      When I call to home the X and Y axis, each will move the unintended axis by an amount. For instance:
      ; homex.g
      ; called to home the X axis
      G91 ; relative positioning
      G1 H2 X5 Y5 F10000 ; move X away a little so the switch is not pressed
      G1 H2 Z3 F2000 ; lift Z 3mm
      G1 H1 X-400 F8000 ; move left 400mm, stopping at the endstop
      G1 H2 X15 F8000 ; move away for second pass
      G4 P500 ; wait 500msec
      G1 H1 X-300 F300 ; (second pass)
      G1 H2 X5 F8000 ; move away from end
      G1 H2 Z-3 F2000 ; lower Z
      G90 ; back to absolute positioning
      G4 P100 ; wait 400ms
      This will result in the following action...
      https://youtu.be/tIwjT1t_1GY
      Notice that the Y axis has shifted on the move away ( line 8 ) yet it was NOT directed to do so, and repeats the unwanted Y axis movement again at the end. This behavior also occurs similarly on the X axis when the Y axis is homed.
      ; homey.g
      ; called to home the y axis
      G91 ; use relative positioning
      G1 H2 X5 Y5 F10000 ; ensure gantry is clear
      G1 H1 Y400 F5000 ; move to the front 400mm, stopping at the endstop
      G1 H2 X0 Y15 F5000 ; move away for second pass
      G1 H1 Y400 F300 ; (second pass)
      G1 H2 Y5 F8000 ; move away from end
      This results in the following:
      https://youtu.be/gej-0meBDWk
      Am I neglecting to give some instruction to the axis NOT being homed somehow?
        dc42 administrators @Nuramori
        @Nuramori said in Strange homing behavior in all betas.:
        That line moves Y by 5mm as well as X
        • Nuramoriundefined
          Nuramori
          Correct, but that's the initial move to set up. there's the other moves that are limited to only a specific axis, but the other axis is also moving.
          this results in an Y axis movement
          In the first video, the action at 0:05 is represented by line 7. watch right after there's a shift on the OTHER axis.
            Ignore my previous reply. It's because your machine is a CoreXY and G1 H2 moves are raw motor moves. So G1 H2 X moves only the X motor, which moves both X and Y axes. A G1 H2 Xaa Yaa move will move just the X axis, and a G1 H2 Xaa Y-aa move will move just the Y axis, assuming your kinematics is standard CoreXY and you haven't altered the motion matrix.
            Nuramoriundefined 1 Reply Last reply Reply Quote 0
            • Nuramoriundefined
              Nuramori @dc42
              @dc42 Thanks. I got it now. I was making it more complicated than necessary.
              Now it works as expected with :
              ; homex.g
              G1 X5 F8000 ; move away for second pass
              G1 H3 X-300 F300 ; (second pass)
              G1 X15 F8000 ; move away from end
                @Nuramori, did you mean to have a G1 H3 command?
