[Solved] Duet 2 Wifi Printing Slow
  • undefined
    AlexTheGreat
    I'm having really slow printing times now that I've got my duet 2 wifi up and running. The slicer says it'll take an amount of time but the "file progress' section is considerably higher.
    Why is it taking so long to print things all of a sudden?! I made sure to change the start g.code in Cura to Reprap. So I don't think that's the issue. I'll include my config below. Any advice?
    ; generated by RepRapFirmware Configuration Tool v2.0.4 on Wed Oct 09 2019 21:00:05 GMT-0400 (Eastern Daylight Time)
    M550 P"Ender 3 Pro" ; set printer name
    M918 P1 E4 F2000000 ; configure direct-connect display
    ;M551 P"Admin" ; set password
    M552 S1 ; enable network
    M552 Phttp://192.168.0.25 ; Set to Alway this address
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P3 S0 ; physical drive 3 goes backwards
    M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm
    M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X1200.00 Y1200.00 Z250.00 E2500.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X235 Y235 Z260 S0 ; set axis maxima
    M574 X1 Y1 Z1 S1 ; set active high endstops
    M558 P5 H5 F500 T4000 X0 Y0 Z1 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X5:205 Y5:165 S20 ; define mesh grid
    G31 P25 X-48 Y-11 Z0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
    M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
    M143 H0 S150 ; set temperature limit for heater 0 to 150C
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
    M143 H1 S285 ; set temperature limit for heater 1 to 285C
    M307 H1 A385.6 C166.8 D15 V24.1 B0
    ; BLTouch - Heaters
    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    And the start g.code
    M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
    M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
    M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
    M220 S100 ;Reset Feedrate
    M221 S100 ;Reset Flowrate
    G28 ;Home
    G92 E0 ;Reset Extruder
    G1 Z2.0 F3000 ;Move Z Axis up
    G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
    G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
    G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
    G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
    • undefined
      Veti
      post the start g code from your cura configuration.
      • undefined
        AlexTheGreat
        G28 ;Home
        • undefined
          Veti
          @AlexTheGreat said in [Help] Duet 2 Wifi Printing Slow:
          remove those and restart your duet before the next print
          undefined 1 Reply Last reply 3 Nov 2019, 16:15 Reply Quote 1
          • undefined
            AlexTheGreat
            I'll give it a try now.
            • undefined
              AlexTheGreat @Veti
              @Veti It's flying along like a bat out of hell now! Thanks!
              1 out of 6
