    Unexpected end of JSON input
    Duet Web Control
    220
    • DeltaCon
      DeltaCon last edited by
      My duet (0.6) is regularly disconnecting with the error message above.
      When I try to reload the page I am getting a download of a file called "download.gz". When I unzip that file I get a reprap.htm that loads the DWC interface without CSS. Only a powercycle gets control over DWC again. At first I suspected the SD card but I changed that for a modern quick one and the result is no-change.
      Firmware Name: RepRapFirmware for Duet
      Firmware Electronics: Duet 0.6
      Firmware Version: 1.24 (2019-06-13b2)
      Web Interface Version: 1.22.6
      Since the machine is running it's job without issues, I suspect it is a DWC thing going on.
      Anyone have an idea about this?
      If you think trial and error is dangerous, try routine. That's even more so!
      DeltaCon 1 Reply Last reply Reply Quote 0
      • DeltaCon
        DeltaCon @DeltaCon last edited by
        After a reboot M122 shows me this:
        M122
        RepRapFirmware for Duet version 1.24 running on Duet 0.6
        Used output buffers: 5 of 16 (11 max)
        === System ===
        Static ram: 44204
        Dynamic ram: 42396 of which 3512 recycled
        Stack ram used: 136 current, 2556 maximum
        Never used ram: 5636
        Last reset 00:03:58 ago, cause: power up
        Last software reset at 2019-10-02 20:07, reason: User, spinning module GCodes, available RAM 2572 bytes (slot 1)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff
        Error status: 0
        Free file entries: 10
        SD card 0 detected, interface speed: 21.0MBytes/sec
        MCU temperature: min 19.6, current 24.7, max 25.8
        Date/time: 2019-11-06 19:15:32
        Slowest loop: 9.59ms; fastest: 0.10ms
        I2C nak errors 24, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 24
        Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms
        === DDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
        Bed heaters = 0, chamberHeaters = -1 -1
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Free connections: 15 of 16
        Free transactions: 23 of 24
        Locked: 0, state: 4, listening: 20071bf4, 0, 0
        • DeltaCon
          The disconnection just happened again.
          I downloaded pronterface and connected over USB with no issues. Now the gcode terminal says "Webserver: rejecting message with: not found" when I reload the page and m122 gives me:
          Used output buffers: 14 of 16 (16 max)
          === System ===
          Static ram: 44204
          Stack ram used: 1080 current, 3940 maximum
          Never used ram: 4252
          Last reset 01:37:08 ago, cause: power up
          Error status: 4
          [ERROR] Error status: 4
          MCU temperature: min 27.0, current 27.3, max 27.6
          Date/time: 2019-11-06 20:48:41
          Slowest loo
          So... it seems to not finish the command output completely.
          • T3P3Tony
            can you try the latest firmware:
            https://github.com/dc42/RepRapFirmware/releases/tag/2.04
            www.duet3d.com
            • DeltaCon
              DeltaCon @T3P3Tony last edited by
              @T3P3Tony , Thanks, I missed that one and thought my recent update was still the latest.
              Will try, but I must say that this problematic behaviour was already showing many updates ago, but seems to be more problematic now, what could be since the update to 1.24 indeed.
              • DeltaCon
                DeltaCon last edited by DeltaCon
                Also version 1.25 shiws this problem. It tries to reconnect, that succeeds after some time, but immediately followed by a new disconnect. DWC then shows "No more free sessions!". After a few times it does not reconnect at all anymore.
                I connected the USB while printing (did not know if that would work but i does) and put in an M122:
                RepRapFirmware for Duet version 1.25 running on Duet 0.6
                Used output buffers: 16 of 16 (16 max)
                === System ===
                Static ram: 44204
                Dynamic ram: 42380 of which 3528 recycled
                Stack ram used: 1080 current, 4076 maximum
                Never used ram: 4116
                That's all I get, a lot shorter than usual...
                  What's happening is that the firmware is running out of output buffers. This is an issue that I was unable to get to the bottom of before the 2.04/1.25 release. Unfortunately I have not been able to reproduce it.
                  • DeltaCon
                    DC I can imagine that you do not want to investigate this problem if it is confined to the 0.6 version of Duet. If you want me to do some tests or give you output/input of any kind, please let me know. I would be happy to do something in return of the great firmware 😉
                      dc42 administrators @DeltaCon last edited by
                      @DeltaCon, it's not confined to the 0.6 version, but the build for the 0.6 version has fewer buffers so if buffers are being lost then they will run out faster.
                      Let me know if you manage to find a way to reproduce it. It's probably related to network activity (multiple network clients? clients disconnecting?), or USB activity, or turning debugging on (M111).
