SOLVED CR-10S Duet 2 Wifi issues
Hello everybody,
I have my CR-10S setup with a duet 2 WIFI but I am running into some issues. The quality of the prints is great, but my printer runs at very low speed. I have read a lot of topics about it and made some changes in the config.g file but still no progress. Also, there is a weird noise on the Z axis when the printer runs at that very low speed. I don’t know what to do at the moment so I am asking you what could cause this weird behavior. I made some videos about the behavior and a voice recording.
Through this link https://drive.google.com/open?id=1nMvOG0Egpb-0P1nwaSZzZATdG4cEPzgeYou can access the files.
I hope somebody can help me.
are you using cura?
newer version of cura have special instructions in the start of the g code that is not made for duet firmware, which slows it down.
are you using cura?
I use Cura 4.0 with creawesome mod
remove the
M201
M203
M204
M205
lines form the start code in the printer config in cura.
Thanks I will do a test with it hopefully it is solved
dont forget to restart your duet or the old settings will still apply.
Thanks this solved my problem
