    Steps Per Revolution Issue?
    • TLAS
      TLAS last edited by
      Sorry, I really think this should be easy.
      5mm pitch ballscrew
      200 steps per revolution motor
      equals 40 steps per mm.
      But when I'm running the Duet, I'm off by a factor of ~15 (likely 16). When it's supposed to move 5mm, it actually takes 75ish for a full rotation.
      I don't have any microstepping enabled in the firmware.
      ; Axis and motor configuration
      M569 P4 S1 ; Drive 4 goes forwards
      ; Motor Calibrations
      M92 X40 Y40 Z40 ; Set axis steps/mm
      M906 X2000 Y2000 Z2000 E2000 I60 ; Set motor currents (mA) and increase idle current to 60%
      M201 X500 Y500 Z500 E500 ; Accelerations (mm/s^2)
      M203 X1000 Y1000 Z1000 E3600 ; Maximum speeds (mm/min)
      M566 X500 Y500 Z500 E1200 ; Maximum instant speed changes mm/minute
      Any thoughts? Seems like this should be a simple one.
      • tomasf
        tomasf last edited by
        Are you sure you don't have microstepping enabled? IIRC, the default is 16x. You might want to try something like [c]M350 X1 Y1 Z1[/c] to explicitly turn it off.
          The steps/mm in the M92 command is the number of microsteps per mm. I know this isn't logical, but it's how 3D printing has always been. The default microstepping is 16x with interpolation, unless you change it using the M350 command.
          • TLAS
            TLAS last edited by
            Ah, that would explain it, thanks.
