    Z-Offset to low - BLTouch, Duet Wifi 2
    819
    • calibanorgundefined
      calibanorg
      Hi All,
      I build a HEVO (COREXY) with a BLTOUCH which i use as Z Endstop & Z-OFFSet Calibration. The BLTouch configuration vice works fine, i used the configuration description of : https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/ (NOTE: as you will see in my config i used P9 instead of P5 which was suggested by betrue).
      My Issue currently is that my first layer is to close to the bed and it always looks like overextrusion (extruder is calibrated). So my suspicion is that it has something to do with z-offset measurement/configuration i do, but what ever i do (re-calibrate, re-measure) it doesn't get better.
      What i tried so far:
      • reduced the Trigger Speed
      • measure with a heated bed
      • uncommented "M501" which i found and not know how it will used😕
      Below i added all my configs including Start and End Gcode plus the start of an example print. It would be great if someone can help to get to the bottom of this.
      Many thanks
      My Duet:
      Board: Duet WiFi 1.02 or later
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC3 (2019-10-08b3)
      Duet WiFi Server Version: 1.21
      config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Sun Dec 16 2018 09:31:03 GMT+0100 (Central European Standard Time)
      G90                                          ; Send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M667 S1                                      ; Select CoreXY mode
      M550 P"machine"                            ; Set machine name
      M552 S1                                      ; Enable network
      ;M587 S"SSID" P"PASSWORD"		     ; Configure access point. You can delete this line once connected
      M586 P0 S1                                   ; Enable HTTP
      M586 P1 S1                                  					; Disable FTP
      M586 P2 S0                                   					; Disable Telnet
      M569 P0 S1                                   					; Drive 0 goes forwards
      M569 P1 S1                                   					; Drive 1 goes forwards
      M569 P2 S0                                   					; Drive 2 goes forwards
      M569 P3 S1                                   					; Drive 3 goes forwards
      M569 P4 S0                                   				   	; Drive 3 goes forwards
      M584 X0 Y1 Z2:4 ;U4 E3 P3 ; Driver 0 For X, 1 for Y, Z=2:4 U=4, Extruder 3 	; Motor remapping for dual Z
      M350 X16 Y16 Z16 E16 I1                      					; Configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E435.134         					; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120           					; v.1.0 Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00      					; v.1.0 Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00          					; v.1.0 Set accelerations (mm/s^2)
      M906 X1360.00 Y1360.00 Z1200.00 E1360.00 I30 					; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      					; Set idle timeout
      M667 S1
      M671 X-25.8:245.8 Y112:112 S6                ; Define positions of Z leadscrews
      M208 X0 Y0 Z0 S1                             ; Set axis minima
      M208 X210 Y210 Z200 S0                       ; Set axis maxima
      ; Endstops & Z-Probe
      M574 X1 Y1 S1 				     ; X home to min. Y home to max. Normally Closed limit switches.
      M574 Z1 S2                                   ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                          ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F80 T4000		     	     ;  X0 Y0 Z1 (old Values) Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
      G31 P25 X21 Y0 Z0.608                        ; v.2.0 was 0.170 v.1.0 was 0.340 was 0.660Set Z probe trigger value, offset and trigger height
      M557 X25:200 Y0:190 S80                      ; Define mesh grid
      M305 P0 T100000 B4138 R4700                  ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                 ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700                  ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280                                 ; Set temperature limit for heater 1 to 280C
      ; BLTouch - Heaters
      M307 H7 A-1 C-1 D-1 			     ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M106 P0 S0 I0 F500 H-1        	             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                    ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                      	     ; Define tool 0
      G10 P0 X0 Y0 Z0                              ; Set tool 0 axis offsets
      G10 P0 R0 S0                       	     ; Set initial tool 0 active and standby temperatures to 0C
      ;M563 P1 D1 H1                      	     ; Define tool 1
      ;G10 P1 X0 Y0 Z0                    	     ; Set tool 1 axis offsets
      ;G10 P1 R0 S0                       	     ; Set initial tool 1 active and standby temperatures to 0C
      M404 N1.75 D0.4	                                   ; Filament width and nozzle diameter
      M376 H10                                           ; Set bed compensation to taper off over 10mm
      ;M501                                               ; Load saved parameters from non-volatile memory
      T0                                                 ; Select first tool
      M572 D0:1 S0.10                                    ; Pressure advance
      My homeall.g
      ; homeall.g
      ; called to home all axes
      G1 Z5 F6000 S2          ; lift Z relative to current position
      M98 Pdeployprobe.g      ; deploy mechanical Z probe
      G1 S1 X-250 Y-250 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 S1 X-250             ; home X axis
      G1 S1 Y-250             ; home Y axis
      G1 X5 Y5 F6000          ; go back a few mm
      G1 S1 X-250 F360        ; move slowly to X axis endstop once more (second pass)
      G1 S1 Y-250             ; then move slowly to Y axis endstop
      G1 X80 Y100 F6000       ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      G1 X0 Y0 F6000		; go back to starting position
      M98 Pretractprobe.g     ; retract mechanical Z probe
      My homez.g
      ; homez.g
      ; called to home the Z axis
      G30 		; Do a single probe to home our Z axis
      G90 		; Make sure we are in absolute mode
      G1 Z10 F6000 	; Rapidly move the Z axis to Z=10.
      i use cura 4.3.0 for slicing
      my Start Gcode
      ; Startup Gcode
      G91                      ; Relative Positioning
      G1 Z-1                   ; Move Z down 1mm
      G90                      ; Absolute Positioning
      G28 XY                   ; Home XY
      M561                     ; Clear any bed transform
      G1 X79 Y100              ; Move Probe to middle of bed
      G32                      ; Start 2-point probe sequence
      G29 S1					 ; Load heightmap
      G1 Z20.0 F6000           ; Move Z to 20
      G1 X5 Y5                 ; Move Head to front left
      G92 E0                   ; Zero Extruder
      G1 F200 E20              ; Prime the extruder
      My End G-Code
      ; End Gcdoe
      G10 P0 R-273.15 S-273.15   ; Turn off Tool0
      G10 P1 R-273.15 S-273.15   ; Turn off Tool1
      G10 P2 R-273.15 S-273.15   ; Turn off Tool2
      M140 S-273.15              ; Turn off Bed
      M141 S-273.15              ; Turn off Chamber Heater
      M106 S0                    ; Object fan off
      G1 E-2 F300                ; Retract 2mm
      G28 XYU                    ; Home XY and U to Z max
      M84                        ; All motors Off
      And an the start example file i print for testing from thinigverse for string test
      ;FLAVOR:RepRap
      ;TIME:1604
      ;Filament used: 0.830472m
      ;Layer height: 0.2
      ;MINX:86.455
      ;MINY:81.302
      ;MINZ:0.3
      ;MAXX:113.655
      ;MAXY:128.502
      ;MAXZ:25.7
      ;Generated with Cura_SteamEngine 4.3.0
      T0
      M190 S60
      M104 S195
      M109 S195
      M82 ;absolute extrusion mode
      ; Startup Gcode
      G28 XY                   ; Home XY
      M83 ;relative extrusion mode
      G1 F1500 E-2.5
      ;LAYER_COUNT:128
      ;LAYER:0
      M107
      G0 F1800 X87.452 Y82.433 Z0.3
      ;TYPE:SKIRT
      G1 F1500 E2.5
      G1 F600 X87.849 Y82.073 E0.02674
      • Vetiundefined
        Veti
        print a flat first layer. while printing adjust with babystepping.
        once you find a good setting adjust the offset with the offset from the babystepping.
        • Vetiundefined
          Veti
          @calibanorg said in Z-Offset to low - BLTouch, Duet Wifi 2:
          2.04RC3
          also i believe there was a bltouch bug in on of the rc releases. please update to the stable 2.04 version
            calibanorg
            @Veti thanks for the fast reply to my question - It worked 🙂 i have a really good layer as it should be 🍾 🍾 🍾
            So what i did:
            • I updated first to 2.04 as recommended -> not sure if that helped but i have experience some unwanted pin deployment after a few seconds of the print start.
            • I downloaded the this flat test square https://www.thingiverse.com/thing:3896687 and started the print as suggested.
            • then i started to do the babysteps (+) as suggested until i found the layer looks good (result was +250) so i removed it from G31 P25 X21 Y0 Z0.608 which gave me the new result G31 P25 X21 Y0 Z0.358
            A note to the last point: i first added it to Z0.608 in G31 which resulted to Z0.850 which put the nozzle much closer. For me a higher number results to higher distance to the bed, but this not the case with this CoreXY configuration.
            @Veti i guess you might have simple explanation for that?
            Anyway thank you so much @Veti i struggled now weeks with this. I read so many forums and howto description and i didn't find anything like what you mentioned to change the offset after the trigger height measurement.
            Calibration print - 1 Layer
            Print after i change G31
            • Vetiundefined
              Veti
              yes. its simple but i get this wrong some times as well.
              your babystepping was +0.25mm. that mean the head had to be moved up.
              now a trigger height of 0.6mm means that when the probe touches your bed the distance from there to the nozzle is 0.6mm
              So with this this offset if you start the print the nozzle moves 0.6mm closer to the bed.
              if you increase the offset to 0.9mm the nozzle now needs to move 0.9 mm closer to the bed when printing. thus squashing into the bed.
              calibanorgundefined 1 Reply Last reply Reply Quote 0
                calibanorg @Veti
                @Veti said in Z-Offset to low - BLTouch, Duet Wifi 2:
                Okay make sense thanks. With my coreXY the head doesn't move but the bed goes up or down.
                In regards of the odd deploy off the BLtouch pins during print. It just happend during an 8hrs run and it destroyed my print plus the BLtouch itself was crashed ::(
                  Are you definitely running 2.04 final release, not a 2.04RC version? Send M115 to check.
                  • Vetiundefined
                    Veti
                    i am not a big fan of the bltouch. i build this for myself https://www.thingiverse.com/thing:3303618
                    calibanorgundefined 2 Replies Last reply Reply Quote 0
                      calibanorg @dc42
                      @dc42 i did the check as suggested. below the result:```
                      M115
                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-11-01b1
                      That is the final release correct?
                        calibanorg @Veti
                        @Veti so i tried to repair my BLtouch and accidentally cut the electromagnetic wires 😖 so now it is definitely gone. 😤 so your suggestion comes at the right time. i think i might have all parts somewhere...
                          calibanorg @Veti
                          I build the sensor you suggested this weekend due i had all material on hand. The sensor is amazingly easy to build and it worked quite right away.
                          Regarding the config i only changed M558 to P5. But based on the documentation -> https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe "Mode 2" = P2 is might be more suitable?
                          Again thanks @Veti you saved me 50 Bugs for a new BL Touch 🙂
                          • Vetiundefined
                            Veti
                            the ir endstops are either triggered or not. so P5 is the correct one.
