    Two wires endstop
    • Neotko
      Neotko last edited by
      I'm trying to understand a thing. I have NO endstops with two wires.
      On the help it says
      "Duet and RAMPS. If you are using simple microswitches, connect them to the two outer pins of the 3-pin endstop connector. For other types of "
      What means the 'outer pins'? Should I use
      • Z endstop
      • 3.3V
      Or
      -3.3V
      -Ground
      I suppose that outter is referred according to the board img on thw wiki, so it would be pins 2-3 and not 1-2? The 'outer' word did confuse me sorry 🙂
        "outer" means pins 1 and 3, i.e. the endstop connector pins labelled STP and GND on the underside of the board. Leave the middle pin (Iabelled 3V3) unconnected.
        • Neotko
          Thanks!!
