Telnet, response/feedback when command is complete
Hello
Is it possible to get feedback when a command has finished?
I've build some basic macro things in C# (interfacing my duet with telnet) that is currently not possible with the Duets default macro system. Right now I estimate how long time it will take to perform certain tasks and sometimes I'm using M114 to check if a particular part has finished. But when probing etc there is no way to determine when a command/move is finished.
Maybe there is a way that I'm not aware of that gives a "Done" when the command queue has finished?
Regards
Rickard
Unless you have disabled marlin compatibility mode, you should get an OK response when each command has either finished processing, or if it is a movement command, been placed in the movement queue. You can wait until the movement queue is empty by sending the M400 command and waiting for the OK response to that.
