DWC heater fault clear timer goes negative
As the title says the pop up that allows you to clear the heater pop up goes negative.
Is the timer really needed as well as the popup?
Running 2.0.0-RC7 on a v0.6 with 1.24 firmware.
Edit: Now upgraded to 2.0.4, but couldn't see a note about the above bug being fixed. Perhaps using an equality comparator for stopping the countdown rather than equal or less than zero?
@DocTrucker can you show what you mean with a picture?
I'll catch one next time the heater faults.
