    Duet Wifi - M587 unsupported command
    458
    • rotarysmpundefined
      rotarysmp
      Hi All,
      I have a working printer. A Mendel90 derivative a good friend designed. He did the original Duet Wifi set up. I just replaced my WiFi router, so I need to reconnect to the new router.
      I tried the instructions on:
      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
      I am at an older version 1.18.1, but since it was working before, don't want to add variables by upgrading.
      In YAT I get...
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-04-09<LF>ok<LF>DuetWiFiServer version 1.03 (ch fork)<LF>Flash size 4194304, free RAM 34296 bytes, WiFi Vcc 3.07V, host name: duetwifi, reset reason: Turned on by main processor<LF>WiFi is running as an access point with name DuetWiFi<LF>
      M552
      Network is enabled, configured IP address: 192.168.1.10, actual IP address: 0.0.0.0<LF>ok<LF>
      M552 S0
      WiFi server stopped<LF>ok<LF>
      M587 S" removed from this thread " P"removed from this thread"
      unsupported command: M587 S"xxxxxxx" P"xxxxxxxxxx"<LF>ok<LF>
      I then tried the Macro method from here:
      https://www.instructables.com/id/Duet-WiFi-Activate-and-Connect-the-WiFi-When-It-Do/
      M552 S0<br>G4 P10000
      The instructions in the link above say to start the WiFi with M552 S0. I thought that ends it?
      Anyway, I pulled the USB plug, replugged it and restarted YAT and have...
      M552
      I get:
      M98 P/macros/SetNetwork
      Dud IP address: M552 S0<br>G4 P10000<LF>WiFi server stopped<LF>unsupported command: M587 S"xxxxxxxx" P"xxxxxxxx"<LF>ok<LF>
      Checking the G-Code list, that M552 P100000 seems weird, so I tried replacing it with P0.0.0.0.
      Now when I call the Set network macro, it doesn't error out on the first line, but I get the same "unsupported command" error on the second line.
      unsupported command: M587 S"xxxxxxxxxx" P"xxxxxxxxxxx"<LF>ok<LF>
      I searched the web, but only found one link to this behaviour, but that thread drifted off into a Z homing issue.
      I would appreciate your help in getting this reconnected and running again.
      Mark
      rotarysmpundefined 1 Reply Last reply Reply Quote 0
        rotarysmp @rotarysmp
        @rotarysmp Sorry, that header should read M587. If an Admin could ammend it, I appreciate that.
        Mark
          The connection instructions were completely different prior to firmware 1.19 and the associated WiFi firmware. Use a smartphone to look for wifi networks, find the one called Duet, connect to that (I think you may need to enter IP address 192.168.1.1) and enter your access point details there.
            rotarysmp
            Thanks for you prompt response, and for correcting my error in the header.
            So if I understand that correctly, I need to go into the new WiFi access points setup and connect to the Duet, rather than use the Duet to connect to the axis point?
            Mark
              dc42 administrators @rotarysmp
              @rotarysmp said in Duet Wifi - M587 unsupported command:
              Mark
              Yes. With the old firmware, when the Duet can't find an access point to connect to, it provides a temporary one itself that you must connect to in order to enter the settings for your router.
                rotarysmp
                If I go the other route and upgrade from 1.18 to the current version, were there any significant changes which will need to modified in my printer set up?
                  Some changes to config.g may be needed. Look at all the "Upgrade notes" sections at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md, from version 1.19 up to the latest version (2.04).
                    rotarysmp
                    With some help from my mate and this thread:
                    https://forum.duet3d.com/topic/1595/quick-fire-question-change-wifi-network-ap-router
                    ...it is up and running again.
                    Thanks for the support.
                    Mark
